  • Replies 107
Would you happen to still have this rod (sorry don't know what it is called), it is connected to the left (passenger side) rear wheel.
Hey mate,
Pm's aren't working yet, can Email me and ill send pics etc.
Cheers,
Mark.
hey mark been trying to call you to work out time to pick up parts
Hey mate, sent you a text your pm inbox seems to be full or some other kind of issue, get back to me later on today.
Cheers,
Mark.
REMAINING PARTS HERE PICS INC WANTING TO CLEAR MOST OF IT BEFORE XMAS OPEN TO OFFERS -
Haltech E6x ecu and standard rb25 loom, has been set up as a piggyback - $680
Aftermarket 3" front dump pipe with cat in pipe - $120
Front and rear calipers $250 for the fronts $120 for the rears
Rear Bar - $100
Rear pillar trims $10 each
Passenger rear trim $10
Diff including upper and lower control arms and cradle $280
Dash pad $80
Rear rotors $40
Turbosmart boost tee $20
Door trims $20 each or $30 for the pair
Misc other dash and interior trims from $5 each
WIll swap items for the following -
-R32 actuator
-3" cat
-Split dump pipe
-R34 op6 turbocharger or similar
Pm or reply here or Email me
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
