Just got a couple of new stickers for the car, took a pic of some of them, still got heaps more, trying to just have a couple of stickers on the rear tailgate, and after that i will cover my whole front bumper with just stickers.
here are some pics of the stickers, will post back soon with how they look on the car:
(sorry about the crap photos, i havent cleaned my lens in a while.
https://www.sau.com.au/forums/topic/338869-got-mah-self-sum-stickers/
yeah, of course, i know there is a heap of people out there that wont like the stickers, i wont blame them. each to their own.
i just seem to like stickers on cars, i dont know why. guess having alot of asian friends dont help the cause. :D
oh come on. its really not at all that bad. i mean i love the look of a perfectly stock car and old skool classics like a mustang bog stock etc, but every now and then i also like to have some fun on my everyday ride.
but i guess skyline's, sylvias, or 180's are suited more for the whole stickers scenario i guess.
as long as they're not offensive, go for your life with stickers: to each his own... But remember: whatever one Stagea owner does affects the general public's opinion of all Stagea owners... "Pedo Bear"? (assuming it implies what I think it does..) REALLY?! :banana:
pedo bear is kinda like having a 4chan sticker on your car, its an internet sensation. i wont fill my car up with stupid crap, most offensive thing ill ever have is the boost sticker.
oh and that pedrobear looks pretty awesome, one shall be made into a sticker and stuck somewhere of my choosing if its not trademarked to you :banana:
I had a sticker on mine I custom made for my car and my best mates gtr saying
"my bungfritz brings all the girls to the yard"
personal joke,and it's written in super cursive letters so other people could never work out wat it says
na, i bought one from house of grafix in the us
i bought a few different ones off them and put a subtle one on my car
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
