Whats Changed?!
@Murray_Calavera I was using the scuff pad today and noticed, it didn't take the shine off as easy as I would have thought and will take ages to do the whole car by hand. Unless I go in a circular motion lol. Would a random orbital sander with a scuff pad attached be the best way to approach it? One thing I wanted to check when you said to check the areas that I sanded, does that mean if I sanded one area a bit too much (not to bare metal but more than another part of the panel) to make it even I need to put body filler even if there is no damage there?
By SeanR32GtSt · Posted
That’s a good question. I’m not sure. It feels laggy for sure. How can I diagnose that? -
Merry Clitmas you dirty cnuts. 24 hours ish in the sous vide at 50°C, then finished it off in the pizza oven at 500°C. Internal temp peaked about 56°C, albeit a bit higher than I wanted however still butter soft. Don't ever let the mother in law out cook you at family events. Yes, that plate was bought in Ischia, Italy. -
Is your VCT working? That curve looks like your VCT isn't engaging
