Thinking of getting some cam gears but don't know which brand to go for. You can get Tomei's for around $400 or you can get ebay specials from as low as $130 a pair.
My experience with cheaper brands gears on my old 4age where not the greatest, they were Fidanza and the color faded after a few months.
Is there any cheaper brands that are good? Or should I just cough up the dough and buy the real deal?
https://www.sau.com.au/forums/topic/338882-what-brand-cams-gears-to-buy/
cheaper gears are fine - generally though just change the bolts out for better quality ones.
cam gear cover sits over them, so who cares what they look like? :D
You can even have stock gears modified for around the price of ebay ones
personally a cam gear i something that i would never cheap out on... they can slip and you want to be sure that the correct materials have been used in manufacture.... which is something china can never offer.
fwiw i run greddy
:D
fwiw i run greddy
Hence i said change the bolts - they are the only downside and can be fixed up for $15 or less, $200+ cheaper than the jap items :D
Racepace mod stock gears into adjustables, just use good bolts and tahts that!
yeh.... i'd be happy to use a race pace modded stock gear, but not a china one.... who knows what density the metal is, if it gives even a tiny bit, then BAM
unless it's for looks... then it's HKS all the way :D
Ok I'll look into the GCG ones.
Would 3 bolts be enough to hold them? A mate at work said to not buy ones with 3 holes like the HKS (GCG are the same I think) ones as they tend to slip. But if you lock tight them they shouldn't come loose.
Edited by eightsixboy
Greddy cam gears here...nothing but jap touches my rb26, sometimesthe cheaper ones have the advance and retard markings the wrong way around
yeah i was fan but they have discontinued some of the range :) like sr's are no more...
swapping the bolts out is a fix, but that doesn't help if the threads are sloppy or the material is soft around the thread area, but you can get around it with loctite.
But a smashed motor is way more costly than the $200-300 your trying to save, so a quality item is cheap insurance in some ways.
this
LOL @ all the people saying only buy jap ones, when up until the latest HKS cam gears were renown for slipping and the tooth material wearing. From what i have seen the outers on most of the cheaper gears are steel, and 5 bolts, just the qualtiy of the capscrews are poor.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
