G`day Mike. If your R34 GTR turbos are steel rear wheels i`ll take them. I thought the R34 GTR turbos were the same as N1`s. What`s the differance? You can contact me on 0438 067 797 Adam.
https://www.sau.com.au/forums/topic/338888-r34-gtr-turbos/#findComment-5475793
BNR34 (14411-AA300)Ceramic~225PS
33N1 (14411-24U10)~280PS steel = hks gtss turbo eqiv
34N1 (14411-AA401)(14411-AA402)(14411-AA403)~250PS steel
thats the diffrence.
If they are ceramic they are only good for replacement for stock turbs with stock boost.
Edited by Gtir-keiron
https://www.sau.com.au/forums/topic/338888-r34-gtr-turbos/#findComment-5475948
Only n1's have steel wheels . These are ceramic ball bearing turbos, unlike r32 and r33 gtr's turbos which are bush bearing and ceramic.
cheers
Mike
https://www.sau.com.au/forums/topic/338888-r34-gtr-turbos/#findComment-5478530
i thought r34 gtr turbo's where steel, but i could be wrong, grab magnet and see if it attracts to the exhurst wheel, a fridge magnet will do just see if it attracts to housing through the soot and ifso then the wheel
Edited by XKLABA
https://www.sau.com.au/forums/topic/338888-r34-gtr-turbos/#findComment-5482384
The R34 N1's are steel wheel..normal R34 are ceramic..as are the ones pictured.
https://www.sau.com.au/forums/topic/338888-r34-gtr-turbos/#findComment-5493071
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
