Hi Guys
Im your newest member so HI!! I currently own a 300zx TT and I am looking to import an R32 GTR as it is my absolute favourite, as my daily driver.
I am really after the V-spec model but I dont know what years they were made, were they made from the begining 89 up to the end of the production? Or were they specific only to a certain year?
Also I have never seen one for sale, I just know they exist, so what price would you think they go for landed here?
Thanks for all the help in advance, I hope you guys go on cruises and such, as I will be hungry to mingle with the skyline crew here in QLD :O and sorry if my questions are noobish
According to http://www.rbmotoring.com/gtr32.html
02/03/93
Minor change Late model. V-spec added
Rear dif cover fin removed
Clutch modified (push -> pull)
Synchronizers modified
Brembo caliper added(V-spec)
ETS program modified(V-spec)
Tires changed (V-spec: 225/50-17)
BBS mesh special wheel (V-spec)
# N1 model gets to based on V-spec
I would imagine that $30,000 landed would be about what you'd pay for a clean, sub 100,000km 1993 GT-R V-Spec.
T.
I realize your new to the forums, but a search on this subject would be the best, seeing as this subject has been discussed umpteen times...
Click for V-Spec info
Thanks Tony, that info/page is exactly what Im after.
I know all the differences between v-spec and normal which is the only info search returned, I wanted to know WHEN they were made in the production cycle, so according to this site they diddent start until 93, great THANKS tony!! :headspin: :O
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
