Hi,
I'm hoping this thread is in the right section because I couldn't find any section with electrical questions.
Anyway, I've viewed a whole bunch of wiring diagrams but haven't been able to find what I'm looking for.
I'm trying to get the dash and other thing's in the cabin wired up in the car I have fitted the engine into ( yes its a volvo )
There is a big white plug on the engine harness, close to the Big blue plug that goes into the ECU.
The white plug connects to the harness inside the cabin for the accessories, in particular, the instrument cluster inputs (speedo, tacho, temperature, boost gauges etc.) I think it also has the wiring for the Ignition switch on it and a few other relays.
Either way The plug broke when I was being removed, which is ok because I only need to use the necessary outputs to get the car going.
The diagrams that I have seen with this plug on them (a lot of the engine wiring diagrams don't even have the big white plug on them) only have codes to identify each of the outputs for the wires.
Can any one point me in the right direction here, it would be much appreciated.
I've just circled the plug I'm talking about on this diagram (sorry bout the size if I reduce it anymore you cant make out any of the letters, its already a bit distorted.)
I'm thinking of stripping the harness in the cabin and tracing each of the wires from the plug to the relevant component, like the ignition switch for example. But when it comes to the instrument cluster its impossible to figure out what goes where. I might try looking for a wiring diagram just for the instrument cluster.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
