Well as no surprise I'm selling my R34, Nothing wrong with it just over it. Looking at mainly cash, But could be keen in some swaps show me what you have got but would like cash my way. Car goes fairly well for what's done to it just needs a tune, fuel pump and some boost wound in to it and would go awsum :)Car is always run on BP Ultimate and gets around 500km to a tank. Engine is very healthy no leaks knocks etc, Had a service about 1,000km's ago. Interior is very clean for it's age just missing the gear boot but they can be bought of ebay for around $40. Now to the bad points of the car. Body - Rear bar has two cracks (pictures attached) BUT! do have a replacement bar in perfect condition just needs to be painted :) Have taken the spoiler off which has left the holes, Spoiler will come with the car it was just taken off cos I thought it was ugly. Drivers side guard has a pin dent and rear passenger side coilover has a knock (but do have replacement shocks)
Anyway here is a bit of a run down of what is done to the car
1998
Manual
Turbo
107,xxx Kms
Had 100,000km Service (belts water pump etc)
All Oils (diff + gbox)
Head machined
New gaskets put in
New timing belt
New water pump
Fresh rad coolant
New thermostat
New rubber grommet around harmonic balancer
Machine rotors
New rocker cover gasket
Rotors Machined
New spark plugs
Mods:
Boost Gauge
Water Temp Gauge
Oil Temp gauge
Red silicone radiator kit
Apexi AX5370 (400hp Ball bearing) turbo
Braided Turbo oil and water lines
Apexi Air filter
Splitfire coilpacks
HSD Coilovers
Hybrid FMIC
8000k HID
Full Set Of Skyline Floor Matts
Fire Extinguisher
Front suspension rack fully rebuilt + serviced
Aftermarket Lower control arms,castor arms, tie rods, tie rod ends
HICAS lock kit
Traction control removed
Catback Exhaust
Nismo Front bar
Nismo side Skirts
Nismo Rear Bar
Nismo Wing (removed but comes with car)
AVS 17x8+17x9 Rims
New Tyres
Pioneer Head Unit
Alpine 6" speakers in front
Alpine 6" Speakers in rear
Spares
SMIC
Air Box
Stock shocks
Full Set Of King Springs
Nismo Cannon
Triple Gauge cluster
Plus Lots More
Anyway looking at $17,500 which I think is fairly cheap considering what is done to it
https://www.sau.com.au/forums/topic/338924-r34/
  • 4 weeks later...
Ok this seriously needs to go $15,700 few changes put the standard turbo back on as the apexi has a little to much shaft play for my liking, Also car is getting a service thoe week. Or $15,500 with no sound system
https://www.sau.com.au/forums/topic/338924-r34/#findComment-5561627
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
