Hi guys,
I was driving around for a fair while with a few leaks within the gasket and power steering hose. So this week i got everything fixed up mechanically. Whilst they were checking out the car they noticed my fuel tank was leaking and the seal had somehow moved to within my tank. So petrol was leaking from my car (Which explained my complaints about fuel usage). Anyway they had repaired everything and i finally got it back yesterday. I noticed whilst i was driving when i went to accelearate in a higher gear it would hold back and jolt slowly into acceleration. It was like there wasnt enough fuel being released and a leakage had occured. I also droved it last nite and noticed it had gone worse. I brought it back there this morning and the mechanic was a nice guy and took it for a drive. He was speeding most the way and hadnt noticed any jolting. Now when i drive it i slightly notice this jolt but only in higher gears (3 & 4). He had said it may be a missifing problem and my spark plugs may be old/not close enough. But i was driving around with these new spark plugs (2 months old) without any problems. Do you guys reckon theres more behind it and may be a fuel problem? or may i need to get new coil packs or tape my standard ones up?
Thankyou
https://www.sau.com.au/forums/topic/338953-boostingaccelerating-problem/
What gap are you spark plugs at and how much boost are you running?
It could also be your coilpacks breaking down. Taping them COULD work for awhile but due to the heat the tape would get brittle and eventually break apart - and you wouldnt want that falling into the spark plug chamber as you remove them out next time!
I'm using NGK Iridium BPR5EIX.
Which I'm pretty sure is a 1.1mm gap. But what i dont get is that it shouldnt change what the engine was previously doing? all that was done was a rocket cover gasket change?
My guess is th at it is the coil packs that are the problem. Do you guys recommend the industry grade silicon in fixing the problem? So that it doesn't pollute and go everywhere.
cheers for the help guys
Try gapping your plugs like krishy said. Also with your coilpacks I coated them in high temp silicon which did the trick. If your spark plugs are gaped to 1.1mm then when your on high boost it will blow the spark out. Like blowing out a candle. Gapping them to 0.8mm will stop the spark from blowing out
fouled plugs could occur with a whole lot of other factors
hey its matt the 1 who checked your car on saturday and like i said u had alot of loose intercooler piping hose clamps and the pipes were close 2 coming out. so once i tightened them again there is a chance that there were leaks there but not anymore so the spark plugs could have been fould previously. so now it could b running how it should be and wanting to produce more power but cant due to fould plugs or faulty coilpacks.
anyway this is a mates account but let me know how u go if u do change plugs or coils.
Cheers guys
i'm gonna open it up tomorrow and have a look at it inside.
See what the hells making it missfire.
Cheers Matt ill let you know how it goes and thanks for the fix up's i appreciate it all..
I will firstly try out the spark plugs and then silicon up the coil packs should fix it :D
if it doesnt i will clean out the AFM & pod and see how that runs
if all fails does anyone have any other possible problems that may be causing it?
also make sure that all your cooler piping is tight as well....
if your AFM gets dry solder joints in it your ECU will go into limp mode
i have had mine fail twice now, first time intermittently it would cough and splutter as i would be driving and it would sort of fix it self, the 2nd time it wouldn't drive at all past 2500rpm
coil packs will normally be more top end, i would be going with intercooler piping as i have had all of the above happen to me lol, i replaced my fuel pump and all to find one elbow had a small split in it which made the car surge on acceleration
has the happen to me to steve then i has a full intecooler blow out went down port wakefield rd for 20 mins with hell black smoke to get home was a bad day lol, got home and the back of my car was totally black
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
