hi gang...
im new to SAU, yes i live in NSW but im that close to the border i still class myself as a Queenslander. i scored myself a R31 for free and im looking forward to doing her up and getting it on the road. my nephew gave it to me and its going to be my early midlife crisis car lol.
heres a run down on the car.
R31 GT passage RB20ET
garrett T28 "disco potato" turbo
problems:
control arms bushes need replacing
coil overs in the rear need looking at
theres a oil leak somewhere
in my nephews words "turbo seems to spike sometimes" (turbo to big maybe??)
crack in the "tyre well" that you can see through
sometimes when your driving to get the auto tranny to change gears ya gotta take ya foot of the gogo pedel.
only thing that really has me worried is that crack, once i find my camera charger ill get some pics up
https://www.sau.com.au/forums/topic/338954-hello-all/
Welcome!
Might be a couple of us doing a light drive down towards M'bar soon! might be able to catch up when your cars ready!?
would be great mate, but the skyline wont be one the road for ages yet :-) but ill be at cruises with bells on when shes on the road
thanks for the welcome everyone
https://www.sau.com.au/forums/topic/338954-hello-all/#findComment-5476827
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
