Hey guys
Parting out a Blue (TV3) JDM S15, had 103,xxx kms on the odometer.
Here are the parts that I have for sale. If the part you are looking for isn’t listed, then it isn’t for sale.
Prices are slightly negotiable.
If you don’t have the money, don’t waste my time. I will NOT be holding any items under any circumstances.
Buyer pays postage.
PM me.
Here goes:
Engine:
** S15 SR20DET Engine with loom and standard ECU $2800**
- Only ever serviced with Royal Purple XTR racing 10w40 oil every 5,000kms
Includes the following parts:
- Brian Crower Step 2 Cams – Int & exh: 264 duration, 12.06mm lift (3,000kms)
- Brian Crower Valve Springs (3,000kms)
- GReddy RAS (3,000kms)
- Tomei Exhaust Cam Gear (3,000kms)
Little bit of VTC rattle but works fine otherwise. Doesn’t come with fuel rail or turbo.
** HKS GT-RS 8.0cm rear housing + GKtech braided lines $1550**
- 22,xxx kms
- No shaft play
- 1bar actuator
- MINT condition
**Stainless steel intake pipe to suit lowmount T28 turbos $150**
Can fit either stock AFMs or Z32
**ARC Core $450**
Few bent fins
Spray painted matte black for stealth
Was making 248rwkw with this core
**Greddy Profec B Spec 2 $300**
in as new condition
Comes with all wires, hoses etc.
2 months old
Drivetrain:
**S15 Helical Diff in R200 housing with 6 bolt half shafts $200**
**S15 driveshaft $80**
**S15 standard shifter $20**
Suspension/Handling:
**S15 Subframe $230
Includes all arms and bushes
** Standard S15 swaybars (front and rear) $50**
**Pair Standard S15 rear shock/springs $50**
** Tein Front strut brace $200**
Brakes:
** S15 front and rear brakes $400**
Includes:
Front and rear calipers + pads
Front and rear rotors
Rear hubs
Brake master cylinder
Exterior:
**JDM rear bar with pods $550**
** Nismo Side skirts $250**
** JDM S15 tail lights $150**
** JDM S15 side mirrors with switch $150**
Interior:
** S15 Driver and passenger seat $350**
** S15 rear seats $100**
Or both front and rear seats for $400
**JDM Odometer with Carbon Fibre Dash with Black rings (103,xxxkms) $100**
** JDM S15 climate control unit $120**
** JDM A pillar with boost gauge and sensor $130 includes passenger A pillar**
**JDM S15 Sunvisors $80**
**S15 Rear pockets $70 for the pair**
** S15 boot trim $50**
** S15 Door cards $150 pair (driver and passenger sides)**
**S15 Upper dash half $200**
** S15 Lower dash half $150**
**S15 centre console $80**
**S15 gearboot surround $20** (has the 1,2,3,4,5,6 and R on it)**
**S15 headunit surround $50 (plastic goes around headunit)**
**Clutch, brake and gas pedals + brackets $100**
https://www.sau.com.au/forums/topic/338958-wrecking-s15/
These are the available parts:
Engine:
- Brian Crower Step 2 Cams – Int & exh: 264 duration, 12.06mm lift (3,000kms) $350
- 22,xxx kms
- No shaft play
- 1bar actuator
- MINT condition
**ARC Core $450**
Few bent fins
Drivetrain:
Brakes:
Includes:
Rear hubs
Exterior:
Interior:
https://www.sau.com.au/forums/topic/338958-wrecking-s15/#findComment-5506119
  • 6 months later...
Hi,
Is the standard s15 shifter still available?
Is that the whole piece that goes down to the gearbox, ie has a ball joint, and bushing at the end, as well as the rubber boot, etc etc? or just a gear knob?
Thanks
https://www.sau.com.au/forums/topic/338958-wrecking-s15/#findComment-5796229
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
