Friday 15th Oct Geelong
russ123
 Share
meet up at pit stop car wash behind shell and vacume shop friday 15th oct at 9 pm genaral meet than cruise afterwards not sure where but if any idea welcome on the night want to meet some more skyline owners if no one interested in cruise round just meet up let us know cheers
Yes I think that I would be interested if there are going to be a few Skyline owners & Skyline Australia members as well so yes I would be interested to see what other members are around the area so are there are going to be a few members & owners there????? :banana::D
Yes I think that I would be interested if there are going to be a few Skyline owners & Skyline Australia members as well so yes I would be interested to see what other members are around the area so are there are going to be a few members & owners there????? :D:mrt:
well can't speak for anyone else but i'll be there for sure bud :)
Hi Shane, decided to move to Geelong for work purposes. New job and career. Its going pretty well at the moment. As for the cruise, I don't think i'll be able to make it as i'll probably be in Sydney, would really love to go though. Plus my car, while its on the road i need to put all the mods back and get it tuned properly. Don't really like driving it around untuned at the moment, still got the -5 turbos with everything else standard so I would prefer to put the fuel system and PFC back in and have it running properly. Cheers.
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
