1995 ECR33 GTST
ENGINE:
- RB25DET built by Advanced Performance Machining
- 9.0:1 CP pistons
- Spool rods
- Nitrided crankshaft
- ACL bearings
- ARP main and head studs
- High Energy Pro Bracket sump pan
- Powerbond balancer
- Peterson external belt-driven oil pump
- Ported cylinder head
- Cometic MLS head gasket
- Tomei Poncams
- Tomei cam gears
- Tomei valve springs
- ETM exhaust manifold
- Garrett GT35R (.70/1.06)
- Splitfire coils
- Turbosmart 50mm wastegate
- Turbosmart BOV
- HKS Spec-R FMIC (600x300x100)
- Plazmaman intake
- Plazmaman billet throttle body
- Bosch Indy fuel injectors x6
- Custom fuel rail
- Turbosmart FPR-1200 reg
- 1 x Bosch lift pump
- 2 x Bosch 044
- Custom surge tank
- Speedflow lines / fittings
- K&N pod filter on custom intake
- Standard radiator
- 2 x Maradyne electric thermo fans
- 4in dump to cat, 3in thereafter
- 1 x hot dog, 1 x muffler, hi-flow cat
- Dump unbolts before cat
- Custom catch can
MANAGEMENT:
- Turbosmart EboostII
- Autronic SM4 w/ignition multiplexer
- Tech Edge wb02
DRIVELINE:
- Ford C4 by Protrans (manualised, transbrake, big pan)
- 11in B&M trans cooler
- TCE 4000rpm torque converter
- B&M carbon fibre Pro ratchet
WHEELS/TYRES/SUSPENSION:
- 4 x 17x8in AMG 5-spokes
- 4 x Federal SS595's
- 2 x Std 300ZX 16x7.5
- 2 x MT ET Street Radials
- Whiteline everything
- Bilsteins, swaybars, adjustable stuff, diff cradle etc
OTHER:
- Pioneer head unit
- 4 x speakers
- Autometer tacho, oil pressure, oil temp, water temp, trans temp
- Tech Edge wideband display
- HKS turbo timer
- Sparco steering wheel
- 4-point harness
Have owned this car for more than 8 years and it has served me well. Time to step up to a new project though. Engine makes a solid (safe) 335kW @ 20psi on Unigroup Engineering's Dyno Dynamics dyno. Makes that power through the full exhaust, with the gate plumbed back and with the filter in place. Should make closer to 380kW with more boost. Car is tuned for E85.
Reluctant sale but not in any rush to see it gone (have foolish emotional attachment to it).
Enquiries preferred via email.
$30,000
P.S. Never thrashed!
https://www.sau.com.au/forums/topic/338990-fs-10sec-e85-r33-gtst/
I love this engine, good luck with the sale. A very nice car.
Thanks mate.
Also, I've had a couple of offers of swaps but I already have my next project ready to go so I'm not looking for another car.
  • 3 weeks later...
Car will also come freshly serviced with all fluids changed for spanking new ones and ready to race if required. Car runs Royal Purple 10/40 and Castrol Transmax M.
  • 4 weeks later...
  • 2 months later...
I can't believe you are selling this thing - its been around forever and I remember it setting a few records for stocky stuffs on the way. I also can't believe you can buy this much car with that sorta money. Best of luck.
They were the best times - running mid 11's with standard stuff and a little bottle. There is SO much more left in this setup but you know how it is; wife, kids, house, (new race car - ssshhhh!).
Someone can buy it and go and try to run 9's in it. Remember that the 10.71 @ 128mph was through the muffled 3in exhaust (it can unbolt at the 4in dump pipe), plumb-back wastegate, radial tyres, foot brake (it has a trans brake) and 20psi (~335kW). Give it 28-30psi, drop the pipes, stick some slicks on and use the trans brake and it'll go way harder (high 9's at low-mid 130's is my guess.
Still weighs 3240lbs with me in it. Oh, for the pussies, it doesn't have air-conditioning... There's a belt-driven oil pump where the compressor used to go.
  • 2 months later...
  • 1 month later...
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
