Hi
I have a rb25 r33 polished plazmaman plenum and plazmaman 72mm billett throttle body for sale
This plenum and tb retains your factory AAC valve and TPS .
Item is 6 months old and in excellent condition.
RRP : is $1550 so grab a bargain.
Reason for sale upgrading to bigger custom plenum for bigger turbo.
Pics are not uploading for some reason check plazmaman website.
Item location Blacktown , Sydney . pick up is preferred but can post at buyers cost.
$900
Thank You
Jason ph: 0405 664 757
Edited by UW8NCY
i thought plazmaman intake manifolds could handle 1000hp or so there website suggests? or is it just personal preference the upgrade? great price though
Edited by Yts
wont separate TB as if some buys plenum they would have to make new flange for stock TB
as for upgrading just personal preference as will be making around 700rwhp and want bigger TB and even flow short runners.
thats if you ordered your plenum for use with the stock TB mine was ordered with the plazmaman billet TB the flange is different as the TB is larger and wont fit a
standard TB !
Edited by UW8NCY
Well unless they have changed something since I last talked to them, the Plazmaman RB25 plenums are made to fit the stock throttle body or the larger 66mm or 72mm Plazmaman throttle bodies. I know this because I have spoken to them regarding fitting the 72mm throttle onto mine.
If you want to fit a larger 80mm throttle body (like they did in Autosalon Magazine) then you have to get a new flange welded on.
Just trying to help you out man. Maybe yours is something different but what I'm telling you is the truth.
Edited by PM-R33
look ive got the stock TB and the bolts holes do line up but the stock TB wont seal properly on this flange .
anyway dont care if it did or not its irrelevant i am selling the plenum and TB together end of story !
need this gone !
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
