So basically I was going from a 60 to a 100 zone, car started reving up and making boost and the engine cut out, died completely.
Fortunately there wasnt much in the way of traffic and I had a mates following me in another car (we were going to go camping). The car struggled to turn over, but got there after a couple of attempts but sounded a bit spluttery and the engine light was on. Managed to limp it back home, but I it wont rev much past 2000 rpm, if I tried it would bounce the revs back and forth over a 100-200rpm range and surge almost like a bunny hop. We pulled in to a servo part way back, my mate was low on fuel. I didnt need to fill up but when I went to restart it it REALLY struggled to get going again, almost thought it wouldnt start up at all.
Ive tried to pull the ECU codes, got four zeros. Took the front end off to check the intercooler piping, and also checked the engine bay - all looks to be fine (Im not a mechanic by any stretch though)
Anyone got any thoughts or suggestions as to what I can do/check to isolate the problem?
Cheers!
https://www.sau.com.au/forums/topic/338999-limped-my-m35-home/
Airflow meter?
That thought crossed my mind too, but surely thatd through an ECU code? http://www.skylinesaustralia.com/forums/Ob...st-t281894.html indicates there are AFM malfunction codes.
Hope you get it sorted quickly.
Cheers mate
Sounds like airflow meter Dunc, at least they have been sourced cheap now, around $80 or so new I think. I have no idea why the codes didnt come up...
Can you borrow somebody's to try?
Its possible to check an AFM with a multimeter, isnt it? Maybe I should give that a go
I take it there arent any AFMs that would work other than a unit off another M35?
Quite a few cars use the same airflow sensor but in a different housing, Subaru use it, and many VQ's like maxima.
i let scotty operate on mine too - and they arent repairable as per the older ones.
so will be a new/second hand one
they are available on yahoo auctions japan.
and before you try a 350Z one wont work as the adaptors are different.
unsure about the skyline v35 350gt but id imagine they are the same as the 350Z
mine did the exact thing about 4 months ago.
i was overtaking a car and was in boost when it died mid flight!!!
it was the air flow meter.
I remembered bits and pieces of your thread - couldnt remember the outcome or exactly what was the go. Its reassuring to hear that someone had the same problem and the fix wasnt too costly.
Time to get in contact with Jesse Streeter I guess, doubtful I'll be able to source one here for cheaper than what I can do on Yahoo auctions!
They are available here, im sure Jetwreck got onto a cheap source...
Airflow meter? Hope you get it sorted quickly.
+1 and +1
AFM Nissan part number is 22680-6N211
It should be the same as used in the 2001-2007 X-trail and the 2000-2005 Pulsar
Or you could pick one up on Yahoo... they are routinely on there for under $30 (ex shipping & commission)
Edited by iamhe77
you serious ?
doubt my 98rexy spare afm would suit surely ?
Edited by PetroDola
mate i had the same issues about two weeks ago, i only just managed to get my car home, i took out the air flow meter and sprayed it with contact cleaner and it worked an absolute charm, the car hasn't gone better, it's always worth a shot.
Cheers!
Have you run over anything? like a rock that could possibly squash your fuel lines?
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
