rb25det power fc, 6 months old $1800
z32 air flow meter (almost new 3000kms) $200
gcg stainless steel high mount manifold t3 flange $500
garret gt3540r .63 rear houseing almost new with only 3000km's on it $1800
turbosmart 45 pro gate $500
custum dump/front pipe $250
would rather sell as package is making over 400rwhp on 14psi safe tune
rb20det stock exhaust manifold and turbo (good working condition
with no shaft play) $300
stock rb20det plenum with tb $100
rb20det motor was running but not healthy (needs water pump) $200
3" catback exhaust with cat $100
stock r32 gst seats good codition $100
s15 bride door trims $400
extra pics to come.
https://www.sau.com.au/forums/topic/339043-rb25-and-rb20-parts/
Where you located? Keen on motor
sorry
located in wingham nsw 2429
just letting you know, the motor is bare
5ky whats you offer on just the commander
Edited by stewari
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
