so i have a ser 2 rb25det cefiro, kkr480, greddy plenum stock injectors and ecu (have 550's and haltech waiting)
Never missed a beat, i built this car.
Car was purchased as rolling shell with 'big fuel pump' unsighted so i have no idea what it is.
drive for 2 hours today. go to shops, wait 1 hour, drive car get 200m sounds like its running on 5 cylinders.
pull over 4 hours later in the rain ive checked spark, fuel, compression. plugs, blow by, crankcase pressure, afm..... no idea
then came good but still sometimes missfiring bad. drive 1 hour back home get 2 streets away and car just starts to die in the ass.
BUT in recent when under load this loud whistling straining noise has been coming from the fuel pump....
can this pump be dieing? cos the missfire was intermitten, sometimes dropping a cyl and then running fine, try and bring it under load (boost) it would just cough and splutter.
Bearing in mind this car has sat and im about to change the 'unkown big pump' to a brand new bosch 040 ive had sitting here and replace the new fuel filter i put in when i put the motor in..
Is this my issue? or are my splitfires f**ked? any ideas?
https://www.sau.com.au/forums/topic/339053-need-opinions-asap-rb25det-issues/
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
