i looked for diagrams but its not hard to determine wat each wire is with a process of elimination.
All you need is a 12V source, easy to find with a multi meter, a ground, again, with multi meter... and the one left over is obviously your signal wire.
Z32(6pins but only 4 are connected 2 are grounds) wiring info is below if you need that but i couldnt find rb26(4pins) afm info
Wire 1 - Not Connected
Wire 2 - Signal
Wire 3 - 12v Ground
Wire 4 - Signal Ground
Wire 5 - 12v Power
Wire 6 Not Connected
pretty sure signal ground and 12v ground are the same thing but most people use the signal ground as the ground thats apart of the loom and the "12v ground" to the chassis somewhere, i dont think it matters if its joined or seperate.
Edited by snozzle
