hmm I must ask Tamma about this.
Also he reckons that the standard pump is good for 300rwkw? He reckons I just need bigger injectors...
your stock pump is almost a 10 years old - designed to run pump.
you sure you wanna take the chance?
Huh? I'm talking bout the lpg pump...
oh my bad. i was wondering after i wrote that? 'what would you use for start up?' my bad.
agree with Scott - on lpg i think you'll be pushing close to the limit of the pump.
Hmm I'm gonna change my mind and get the LPG done AFTER the tune. Spoke to the JTG distributor who advised this is the easiest way.
I think I'm going to run E85 + Gas...this would minimise the timing issues when switching fuel right? (get it tuned for say, 105 RON)....
LPG RON can fluctuate considerably from what I have been told.
105 may be a little ambitious unless you are filling up on Supagas's "Premium" LPG all the time (Guaranteed 110RON)
+1 either way, there'll be the issue of this. Sage222 had an idea on the previous page to simply just fuel cut and shut off near empty - instead of switch fuels.
This would mean you would be able to flick the switch on the emanage.
without continuously driving thinking its still on gas.
Sounds like the way I would be doing it too, however you may need to go back to your tuner to optimize the tune between both fuels once your conversion has been done, unless the installers you are using are proficient in tuning as well, most are not and don't have dyno facilities etc.
Absolutely right!
From personal experience the RON and quality varies considerably....
I would say anywhere between 100 and 110 depending on the supplier/source and the final mix of propane/butane and who knows what other additives/impurities there are!
Yes I have used the claimed Supagas stuff extensively and even that varies by a lot....
LPG fitters and tuners that have been around for a long time will tell you that years ago LPG was much higher octane rating 110+ RON was not uncommon, and you did not have to go to Supagas to get it, BP, shell, mobil, caltex all had it.
The problem with LPG is that the quality varies so much and some manufacturers won't even specify it as a minimum RON,
as Supagas will not publish thier RON ratings either, but a properly tuned performance motor (especially forced induction) does run better with it.
Hmm Tamme from Seaview Gas called and said the car's almost converted...said somthing about my bigger intercooler being in the way???? :blink:
He said that he had my injectors flow tested and claims they're larger then what Sage222 had in his car??!?!?!? I asked him for a figure and he said he can't remember :rofl2:
He's put larger gas jets in also...to give a bit of leeway with the upcoming tune.
Could it be that because of the mod's on my the ECU is dumping more fuel and hence it appears that it's flowing more?
Lol at them gestimating fuel mixtures, I thought you were getting the gas done after the tune...
The stock computer could be doing anything, until you get on a dyno you wont know. (although Cam has similar mods and has been running with no issues.)
Yeah was going to but Cihan thinks its prolly less hassle doing the gas first...no need to return for retune...
We'll see what happens...apparently there is a overide switch which can keep the car running on petrol...should come in handy for the tune
great time to do it mate.. saw 1.55 for regular today.. ouch.
id say that your injectors would be flowing more if your running aftermarket management.. look forward to the results!
my mate filled up at supagas 100% propane for $.57c per litre today. laughing!
Edited by Sage222
Nah I don't have aftermarket engine management fitted...yet
which is strange...we'll find out this arvo I guess!
hmm no, I haven't modded my ECU.
I said that I think the ECU might be dumping more fuel due to the mods (suction pipe, intercooler, exhaust) done to the car...
its the stock ECU...nothing added/changed...
Oops reread my post...yeah I said the wrong thing :blush:
Edited by ironpaw
Gah...apparently the car wasn't ready this Arvo. I only found out when I was halfway there on the train and rang them up. Apparently they can't get the fuel mixture right so its going on the dyno tomorrow...they better not charge me extra!! They want my new Denso plugs too...that means I need another set for the tune in 2 weeks time?
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
