hey mate, any more details?
running? condition of motor? kms? gearbox crunches etc.
Last started 3 months ago, battery is dead now, 98,000 kms, gearbox doesnt make any noises or crunch, car still intact except for interior, stripped stereo system, new clutch was installed 2,000 km before accident, no mods.
Let me know if you need better pics.
