Bought these off a forum member but they will not adapt to what i had in mind for them
http://www.nengun.com/garage-defend/stingray
they are in good condition and designed to fit standard front bumper
450 dollars plus postage
ph. 0413 863207
  • Nope 24
https://www.sau.com.au/forums/topic/339081-garage-defend-front-canrds-34-gtr/
  • 1 month later...
hay buddy
what ill do is when i get home (and it stops fkn raining) ill measure the gap where they would sit in the opening of the front bar. if u could please measure the gap from the front section of the canard top to bottom i could better guage the physical size of the thing.
ill also speak to my mate shane from psi parts and see if we could modify them and remake them again in carbon
thanks dude
Not sure I know where you mean but the front section that wraps around is what i measured.
The outside measurement is 21 centimetres and the inside is 17 centimetres.
  • Nope 24
  • 3 weeks later...
are they universal?will this fit to any r33,33,34 and silvia bumpers? cheers
http://www.nengun.co...defend/stingray
ph. 0413 863207
  • 3 weeks later...
hay buddy
thanks dude
Reproducing these in wet carbon fibre would not be hard at all. The trickest part would be making up the molds -
1) waxing component to be copied with several layers of special wax
2) coating with tooling gelcoat
3) applying poly resin and reinforce with fibreglass mash
4) repeat step 3 until a thick enough layer is built up
5) wait until cured and 'pop' it out
Once the mold is made, you can make copies of the part by using carbon fibre fabric, you could even use carbon-kevlar or even kevlar on its own depending on the look youre after.
The trick is not to stirr up the resin too much when mixing in the hardener (Methyl ethyl ketone peroxide - MEKP) - this creates bubbles and you dont want bubbles appearing all over the top of the layer of carbon fibre.
I've made up many carbon parts by using this technique.
Anyways, hope that helps.
  • 1 month later...
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
