hey guys,
car has developed a tinny rattling sound at idle. it seems to go away with throttle, and then as the revs drop it rattles again.
i got under the car and held one end of a screwdriver to everything i could think of, and the other to my ear - and i suspect it's related to the exhaust. it could be something simple like a loose heat shield or a stone caught behind a shield......but i'm also worried it could be something more sinister - like little bits of ceramic exhaust wheel bouncing around in front of the mesh on the cat converter.......
stock neo turbo has been running 11-12psi off the EBC.......is there any other way i can diagnose other than dropping the exhuast in front of the cat and seeing what comes out? its my first experience with a ceramic wheeled turbo, so any insight would be good!
for example, if the exhaust wheel does sh1t the bed, does it do it all at once, or will the blades break/chip off slowly.....? because the car is still boosting reasonably strong, only paranoia is making me question it....
cheers! Mat
https://www.sau.com.au/forums/topic/339093-name-that-rattling-sound/
if the wheel hits the sides itll really break up, not just small chips...
might just be easier to undo the 2 bolts on the exhaust and see, get the car hot, and spray some WD on the bolts and let it cool down, then theyll prob be easy to undo.
just dont ruin the gasket lol.
11-12psi should be fine.
someone else might have some more insight/ideas
my understanding was that the heat of excessive boost is what kills the ceramic wheel - so you get hairline fractures forming on the exhaust wheel which eventually give way sending fragments flying off at 10000000rpm - i guess my question is - if that happens, will it automatically lunch the turbo - or is there a chance that only small pieces have come off and the turbo could still be functioning, just not at an optimal rate (slower spool). and that those small pieces could be what is causing the rattling, as they are stuck in the front pipe and blowing about in front of the mesh on the cat. could also explain why the sound goes away under throttle as they are getting blasted up against the mesh.
doesnt sound like i'm going to get a confident answer......looks like it'll be a case of getting under the car after work tonight. crap.
Edited by SMOKEYC34
weather or not it is the wheel, might be a smart idea to take your dump off and check the condition of the wheel.
to my understanding (correct me if im wrong) the wheel is only coated in ceramic, so if the coating comes off the wheel can spool still, but the wheel is just smaller??
is boost response still the same? Does it feel laggier all of a sudden?
If so, loose actuator will let the gate "flapper" bounce around and can cause that noise. Common issue/tell-tale sign with hi-flows that use factory actuator so its plausible it could occur with a factory turbo as well.
Failing that - drop the exhaust @ the CAT and see what might fall out! :(
IF bits had come off the turbine you'd know about it. They're balanced pretty precisely and wouldnt last long at all if chunks, even small ones, were missing.
Drop the cat and see if its stuff and/or maybe the dump and have a look-see.
Hate to drop this to ya dude, but I'm gonna call - big end bearings.
A damaged bearing would sound like you're describing, with how it slightly goes away when you stab the throttle and up the revs.
I doubt it'd be turbo related.
Thats true... Drop the oil out and see if there are any silver bits in it. If your keen run a magnet through it and see what comes out.
youd know if the exhaust wheel was gone . the car would be slow as fuc k and it would have dropped its guts when it you were boosting it somewhere.
my guess it its the rusty f**ked "heatshield" double skin what ever the f**k you call it that surrounds the front pipe before the cat . it rusts out and the insulation eventually f**ks off and you get rattles when your engine is idling at a certian frequency and the shit stops rattling above idle
what is your front pipe like?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
