Knocking/ Noisy Tein Coilover
s13-steve
 Share
Hey guys,
the right front Tein superstreet coilover on my car is quite noisy, when going up or down a slight incline or even turning slowly will make loud groaning/ knocking sounds.
The strange thing is that the probably under a year old (I didn't fit they were fitted by the previous owner) - i've had a tyre place near my house have a look, they checked all bearings, bushes, lubed everything up and couldn't find a cause - they said it's most likely the shock itself.
Who should i take it to to get the coilover fixed? any idea on what sort of cost i'm looking at?
Cheers,
Steve
Pretty sure they have 2 year warranty if the previous owner bought them brand new?
I don't have any reciepts but the car was imported stock standard from autoworx and every aftermarket part was installed brand new (coilovers, exhuast, rims, fmic etc etc)
i guess theres no way i can prove how old they are - il book it into wa suspensions and see what they say
welcome to Tein suspension, get them out, fix the broken 1 and sell them. I would recommend something like HSD.
has a got a pillow ball top mount? if so, then the spring is not seated correctly so u get a grinding, knocking sound on slow turns or turn + going through bumps.
take it to a good suspension store and get it adjusted correctly so there's no rubbing
take it to wheels world, 4 Carbon Ct, Osborne Park
had the same thing on my bmw before and they managed to get it installed correctly. they are pricey but u get good workmanship
thats EXACTLY what it does - im not to sure if its pillow ball top mount though? its Tein Super Street Coilovers - which i have read come in both versions - what does the pillow ball top mount look like?
Edited by s13-steve
from memory the tein super street has the pillowball and camber plates. if incorrectly adjusted or installed, the spring doesn't rotate when u turn the steering causing that knocking sound.
get it re-installed and see how u go.
Don't go to a suspension shop telling them the worst. some places wont be able to tell the difference and will just do an expensive rebuild on a perfectly good shock.
ROFL... yes because HSD is alot better quality then tein :D
Teins are not made in Japan anymore if i'm not wrong.
A Jap mechanic also told me that quite a bit of people in the circuit scene in Japan avoid teins now. :mrt:
Very high chance that it's how the spring is seating. Bring it down a workshop who knows what they're doing to get it checked out.
Edited by KeeFy
 Share
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
