Hi everyone,
I found a leak in the hose running from the PCV valve to the intake plenum, while trying to remove it to get it fixed/replaced I managed to split the grommet for the PCV valve - ended up having to remove the rocker cover to get it out.
Making a 5 minute job take almost an hour *sigh*.
So now I've got a cracked hose and no grommet for the PCV valve. I did however have one of those little air filters which by some spectacular fluke actually fits really well.
After taking the car for a drive and removing the filter I had to freeze it for 5 minutes just to get it back in.
I've read a lot of stuff about various catch can setups and seen some people have a setup that completely removes the PCV valve from the picture - and the subsequent caution of becoming pig food.
Now I know that having this little filter where it is; isn't legal - I'm not so worried about that as much as I am about this setup being less then ideal for crank case pressure - or something else that I haven't considered.
The car is running fine now, I didn't see anything wrong with oil pressure or temps - idle is smooth again and holding boost a lot better - I don't wanna do any damage just to save myself the work.
Would you run a mini air filter and block off the hose from the plenum instead of running a PCV valve/blocking it off completely?
I can get a pic of the engine bay if needed to show what I've done.
Tell me what you think peoples!
~Raven
https://www.sau.com.au/forums/topic/339116-pcv-valve-gommet-split-rb25det/
Hi everyone,
~Raven
I believe the PCV is the culprit for spewing oil into the plenum whilst decellerating on a hard left hand turn.
RB's are notorious for this on the track.
I had a plume of smoke after turn 1 at Eastern crk big enough to blind the car behind me, never mind the oil all over the track.
Then oil dripped out my BOV for the next 6 weeks, which is mounted underneath just after my intercooler and up hill.
Proving to me the oil came from the plenum side.
I have N1 oil pump and no ext return though.
Even for 100 % street use, the engine will still vent sufficiently through the turbo.
In regards to the blocking of the Rocker cover to intake manifold PCV, is that illegal even if there is no venting to atmosphere?
You are risking pulling un-metered air - through the filter, across the rockers and down to the inlet side of the turbo - into the air/fuel mix, causing a leaner than expected A/F. And lean A/F is asking for detonation.
Just go to Repco and buy a new grommet. Have bought many before
Went to repco today, got another grommet - I asked them about 'S' bend hoses, they have nothing that comes even close to what I need, they did have those springs you can use to bend a straight hose without kinking it - again nothing even close to what I need, leaving nissan or wreckers (cringe).
I've put about 50k's on the car since I fitted this lil air filter and haven't noticed anything that would make me think I've been drawing in un-metered air, still worried I'm doing damage without knowing.
Zoomzoom, I'm not sure if there is a way to remove the PCV valve and connecting hose without it being illegal. Normally the idea is to vent the oily gases anywhere but into the intake - 'oil catch can' would be the key words, though if setup incorrectly can still lead to damage, defect or do nothing at all.
So I think I'll just goto the wreckers and try get another hose - might even be able to score a heat shield for my exhaust manifold.
Thanks for your input everyone.
~Raven
~Raven
did you actually ring Nissan? or just assume it would be dear? $34.50 and in stock at the springwood store. I'd say it's a commonly sold part and $35 isn't something to cringe about
haha nah I was more cringing at the idea of going to a wreckers and did infact call nissan and will be going to that very store this arvo or maybe tomorrow.
edit: getting the exhaust heat shield was the bonus of going to the wreckers
Edited by Raven33
Forget that, already done. Ask for Craig and tell him you're a mate of mine
sweet as, you rock.
gonna have to leave it till tomorrow morning, but I'll be there for sure.
thanks man!!
~Raven
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
