This car is excellent on fuel and drives beautifully. A much loved car and
regretful Sale.
If your serious about a Skyline, the 1st to see will buy.
Rego till May 2011 and RWC.
145,000 kms
Features:
Factory Xenon Headlights
Factory Nismo Body Kit
Nismo height adjustable Coilover suspension
ARC Intercooler (Fully Legal)
Factory Nismo Dash+ Factory Nismo boost/oil/battery guages.
Nismo Floor Mats
Jasma Turbo back exhaust (epa legal)
Apexi Power FC (tuned by Racepace)
19" Speedy Wheels with good tyres
Nismo Fuel Pump
Viper Remote Start Alarm
plus much more.
Serious buyers only, no joy riders.
Will swap for S15 only.
Contact Alex :0422 780 627
Edited by albwaa
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
