  • Replies 71
am i being too anal about this whole situation, i mean the car can be registered here in oz as it is complianced?;)
Check with Vicroads - they are actually pretty cool about this kinda stuff. When I got my car it was first registered in QLD in 2000 but the compliance plate was dated 2002. So something dodgy went on somewhere. Somehow the car was originally registered under the japanese compliance number. It had never been registered before me with the correct compliance. But Vicroads did all the chasing up through QLD Transport and found the compliancer and everything was sweet. They were really helpfull.
Would you be anal if it was your car that was stolen and shipped overseas and was left paying it off?
I take it this is the car that beefy has advertised on these forums and is discussed in the other thread "where to get a vehicle inspection". I had the same experience with hypertech rubbishing all cars other than their customers ones for sale and would prefer Ben's opinion anyday. How long has it been complied and were the mods done here or in Japan? I think this car may have had a hit in the front from what I have heard. If its already complied then the tag isn't a huge issue is it?
I'd be careful.. its just not worth the risk! What happens if you want to sell it later on? I'm sure others will be cautious enough not to buy without it.
I'm not sure whether the numbers are significant at all, but cars can be stolen and sent out of japan quite easily for those with dodgy connections.. then complied and registered over here also with questionable connections.
Plus, until about 12-18 months ago when they tightened up the rules in VIC it was very easy to simply swap the compliance plate of a smashed GTR with a non-complianced GTR.. AND Vicroads has a reputation for being one of the dodgiest government departments in Australia.
Could have even been a statutary write off, just somehow, somebody managed to get it fixed up and re-registered. The blue plate cannot have simply just gone "missing" for any logical reason other than something dodgy. Clearly??
Cars can be stolen and sent out of japan regardless of whether they have the blue id tag or not as i believe.... as i mentioned b4, the i heard that this car is a 1998 model complied as a 1997 hence that might have to do with the missing plate.
However, mid to high 30's for a good condition 1998 GTR with over $5k worth of mods... it really is a bargain.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
