Guy's I seem to have an issue with my RB30/RB26 conversion and rather high temps under the bonnet. I have a top mount single turbo conversion and the down pipe runs close to the bulkhead. I have it heat wrapped down to the decat pipe but it still seems to get dam hot. Hot enough to melt the clips on the brake pipe and start melting the wiring up by the ABS on the dyno when I did some run in miles! To be fair the fan tripped out on the dyno which probably didn't help. I then go a turbo beanie and some heat refelctive wrap aroud the pipes and wiring and went for a 1 mile drive no real load when I got back the area around the turbo and downpipe was very hot and I am just a bit worried that it is hotter than it should be?
I guess lean fuel or over advanced igntion are the only real possibles here? I know water temp doesn't seem to get that hot that quick if that give any clues? Water temp was ony just start to get up to temp after my drive.
I am going to try and richen the mix and bit and get another timing light to check timing as two different lights so far show two very different timings?!
Is the sensor from the CAT (now in the decat pipe) and EGT sensor? If so can I read it from the Apexi hand commander and roughly what temp should I be seeing that far down the system?
Any thoughts on tis or people with similar problems to put my mind at rest please?
Cheers
Lee
https://www.sau.com.au/forums/topic/339233-rb30-under-bonnet-temp/
you need to ask your tuner about the condition of the tune.
the car did not come with a top mount turbo so you need to make sure your wires are out of the way of the heat as much as possible.
mine melted with my rb30, causes a big short that ended in smoking wires and 4 blown fuses.
some pics would be nice.
Hey there Buddy,
Well tune wise it is basically on the RB26 base map.. I went on the dyno and they put the injector settings in at correct size (I had used compensation values) and it seemed to pull up okay Air/fuel mix without fuel adjusting? This is on no and low load only as I was only bedding it in? Does the Apexi self learn to a certain extent? I am trying to get a copy of the datalog file to check some figures and can post a copy for people to look at in case something is not right? I am tempted to put my compensation values back in even if it does make it sightly rich but then if the Apexi will self correct slightly then it shouldn't cause a problem. I pulled the plugs after the some miles on the dyno and personally I thought the tips looked like they had been running hot? Althought down in the plug was dark the very tip was very pale coffee colour.
AFR's were around 14 and dropping to 12 up the revs around 3500rpm I think.
What are your thoughts on Ignition timing? The light I set it on shows 20deg and the cam angle sensor is adusted slight of centre on the bolt holes. So the slot has less room to retard it. The other light I tried showed it at 35deg advance at the same point. But then there is not enough adjustment to get the timing back correct with this light? So I set it with the first light as the engine starts fine and sounds fine... keys over fine. I am thinking if it was 35degs advance it would be a bitch to turnover?
and fire very quick on the key?
I could be worrying too much but I sure as hell don't want to risk my rebuild!
In only have the picture below so far showing some of the engine bay.
I have now got a turbo beanie fitted and heat reflective mat down the bulkhead and covering the wires and ABS unit in the corner. The turret has heat reflective tape on and all the pipes and wires along the chassis rails have heat shield sleeves on too. I had accounted for most of this but I wasnt expecting the heat to travel as much as it does! So far the only thing that has been damaged is some pipe clips and the A/C drain pipe and bottom of the A/C unit! Problem I see is that all the heat is getting reflected and confined in a very small space and without a vent in the hood there is nowhere for it to escape. Maybe that is the cause of the problem right there? But I don't see all single top mount guys running vents and propped up bonnets? Just want to be sure I have it right and normal!
Cheers
Lee
Edited by leeroy_25
Sounds likeyou need a decent tuner. Shouldn't be guessing with your timing and if you want to protect your build a first class tune is a must (and if you have run it more than half an hour it should be run-in and you want the best tune possible).
mate you need a decent tune on this car. tuner needs to set ignition timing correctly and also needs map the power fc correctly. You think you know how to set ignition timing but on skylines nothing is "generic" especially setting the timing.
when i tune power fc's i like to try to keep the injector correction at 100% and tune the map accordingly. this is the correct way of doing things.
are there no good tuners there who can do this for you? I could offer you a remote tune for a price. all you need is a internet connection (3g pref) datalogit and a decent wideband that has 0-5v output.
If you need to you can hire a dyno and i can tune it over internet for you.
be VERY carefull how you continue with this car, because there is a big chance things can go south if you make the wrong call.
cheers
Titan,
That is pretty much exactly what I have done now!
Guilt-toy.The tuner who is doing it is a rotary specialist who did my RX7 and does all other jap makes too. He did a brilliant job on my rotary. I am just being extra careful and possiby paranoid about the timing and fueling where it is set now as I know the lights can get a dodgy signal using the inductive pickup off the harness. I am getting an inline timing light to check it tomorrow and put my mind at rest one way or another.
I will go from there re the tune. I do not have datalogit unfortunately so a remote tune is not an option.
I am sure once I get a proper map done it wil be great. I just want to have the basics set up so I can drive it for MOT with a clear head and no worries!
Cheers
Lee
I borrow an inline type timing light to check the timing again and it was spot on.. So that puts my mind at rest. SO I fitted spacers under the bonnet to lift the back and it has helped a lot. Much better after a drive up the road.. Still some fumes and a funny smell but I think/hope it is the crap burning of the new turbo beanie which I only just fitted. So I will keep a close eye. The heatshielding I put between the ABS unit and downpipe seems to work well also, just got to check heat is not getting through lower down the bulkhead where it all gets a bit close near where the A/C drain comes out. It has been melted once but now has shielding there too so as long as that is okay I think I am sorted.
Cheers
Lee
is it just me that saw how lean the AFR's that were mentioned?? that would be creating extra heat right there. trying to run a motor in or be on the safe side you'd want it running alot richer...IMO anyway...
Maybe i missed something...
Edited by -_-StRyDeR-_-
^^^Like he said it appears to be quite lean. Do you have a chart to put up? Checking the base timing is fine but it doesn't tell you anything about the rest of the timing. You need Guilt Toy to tune your engine properly (or go on to the UK GTR site to ask for an experienced RB tuner).
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
