Hey guys,
did a bit of a search but came up empty. Google turned up this:
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON. A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Edit: Added the "Easy Method" for ECU Reset
The Easy Method:
After experimenting with different timing, and reading posts by other members, I've come up with a condensed method of doing this reset. This method works EVERY time, even w/o a stopwatch. I've used this method successfully a dozen times, or so, now w/o a watch. After a few times, you won't need a watch or instructions. You'll get so darn good at it, you'll find yourself doing it while waiting at a traffic light.
Timing is not as critical with this method...no stop watch needed. Just count in your head...one-one thousand, two-one thousand, etc, or use stop watch. The most critical step is step #3....wait 10 sec, instead of 7.
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then start engine. Done!
Will disconnecting the battery be an even easier option? Or does anyone have another procedure lol? Thanks.
https://www.sau.com.au/forums/topic/339248-reset-ecu/
Disconnecting battery doesn't seem to work... unless you leave it off for a few days I guess.
That procedure is the same as our M35 Stagea's
Just a quick note, Step 4 above is where the ECU displays any error codes so perhaps it would be a good idea to write them down before moving on to step 5. :laugh:
Also, I compiled a (long) list of error codes that are applicable to V35, M35 etc for future reference.
Edited by iamhe77
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5479956
what reason would one have to need to reset the ECU??
Mainly when U get new mechanical mods, for example things like resetting the knock sensor so the ignition timing is accurate after you've added say a throttle-body spacer, resetting the O2 sensor if you've installed HFC or even something as minor as a Z-tube. IMO Any kind of mod to the intake/exhaust and engine (i.e. bigger injectors) will require an ECU reset. In doing that, the ECU 'learns' your driving style and makes any necessary adjustments. Also, if you want to clear any error codes (e.g. airbag light flashing) an ECU reset does the job.
P.S: I've even heard of people resetting the ECU after an Oil change. I don't, however, I don't have any arguments against it so I won't go into it.
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5484560
How does the ECU learn?
Is it through time spent at different speeds, average speeds, and rates of acceleration or what? Is it always adjusting and if so why would a reset be necessary?
My LPG Emer sequential vapour injection system was recently installed.
These systems piggyback off the ECU I believe and learn how to operate on LPG based on the ECU.
I am thinking of resetting the ECU as I believe my LPG system should be getting better mileage. However as I am in a remote area I am concerned I may somehow stuff up the motor with no assistance within a few hours drive. Currently 6km / litre on LPG everything else seems fine, easy to start ,good acceleration high speed overtaking no problem.
Before the conversion I was getting around 7km to 9km a litre on petrol dending on speed and driving style. I should be getting only 10 % to 15% worse but I have been told it could be as little as 5 %.
Straight after conversion I drove 2500km on the highway in 2 days. I can’t return to the installer until next year.
Vehicle - 1996 non turbo automatic skyline GTS
Any thoughts as to poor LPG fuel consumption immediately after conversion.
i havent run on petrol since conversion as it is a $1-60 a litre on average
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5500787
Disconnect the battery and pump the brake peddle 5 times.
Would the above be for all nissan vehicles or just V series motors?
How long after resetting to factory settings does the system stabilise to a new driver.
is it the time and engine is on or km driven
Under what conditions is the ECU modifying the system or does it do it continuously every second !
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5500801
  • 3 weeks later...
Ok try the long way.
The ECU Resetting Procedures Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone. :)
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU. :D
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5531994
how do u know if u have reset the ecu. Im interested in resetting mine as i have recently bought the car a few months ago and fuel consumption is pretty high. Will resetting the ECU help??
getting 450km per tank on a good day, 370km when i drive with a bit of a lead foot.
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5532164
There is a common problem with the V35 and the fuel gauge. You might need it cleaned/replaced. when it's on the red line "E" you could have a 1/4 tank left. Maybe.
You should get 550km on a good tank.
Edited by V35_Paul
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5532463
tried again....about 20 times, im getting .1-.2 seconds off wen im lapping the stopwatch to the next step and im still getting nothing...should i be trying something different or getting closer - things im thinking i might be doing wrong -
1 - the first step im doing wrong , when do i start counting the first three seconds as soon as i put on the ignition to on or wait till at check light goes off?
2 - also maybe the 5 press and let go (second step), at after the 3 seconds(1st step) is it 1 in and out per seconds or it doesnt matter because im doing it within 3-4 seconds and continuing if i finish the second step before 5 seconds say 3.5 do i wait till 5 seconds then start next step?
Edited by ezy03
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5532827
1. As soon as you turn it "On".
2. Doesn't matter how quick as long as it's within 5 sec. When the peddle is fully out start counting your 7 sec.
If it's not working maybe your problem can not go away with a reset.
What is the problem your having? Why do you need a reset?
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5532856
installed a few mods and it said to reset it, might get my cai in next week and let the place im getting installed at do it, save me the hassle
You don't need to reset it. You can just drive the car around and the ECU will adjust it's self to the new mods. A few hours of driving will do it.
https://www.sau.com.au/forums/topic/339248-reset-ecu/#findComment-5533252
  • 3 years later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
