hey guys
im trying to decide what offsets to get
its still a while till i get them but i wanna know if im being to ambitious
im sick of having such bad offset so im thinking...
lenso d1r's, black 18x9 +15 or 18x10 -1
i think the 10's will be ouf of the guards but i've got a lot of room till that happens
ppl seem to run 10's easily on 33 gtrs so i guess they will fit on the stagea?
i ran the 10's through an offset calc and it said they will stick out 74mm more
anyone running these widths? pics?
hopefully this thread can become a reference point for rs4s owners
Thanks, Tom
https://www.sau.com.au/forums/topic/339249-rs4s-wheel-thread/
A few points to consider when picking wider wheel widths. They will all affect the fitment.
1. Tyre size
2. Ride height
3. Camber
4. Tyre stretch
My car for example. Has series 2 manual rear cradle out of a 'S' in it.
1. 245/35x19's
2. 330mm
3. approx 2deg neg on the rear
Wheel size 19x9.5 +12
With this combination I have approx 10mm inner clearance to shocks and I cannot fit my little finger in between the outer tyre and the guard. Maybe 5-7mm clear. They never rub.
I am looking at reducing the neg camber to approx 0.5 so I will need to roll the guards. It will also increase the inner clearance to the strut.
245's are a little stretched on 9.5's. Will be worst on 10's.
You could get 10's to fit with streched tyres and and some camber with minimum rim outside the guards.
All depends what look you want.
Personally I would stay to max of 9.5's, but everyone is different.
i'm running 18 x 10's on my S2 stagea. not sure of the offset, i'll have a look tonight.
being an auto and having wider track on the rear they hang out a little bit, but i've got 235's stretched on them so they sit okay.
i've also dialed in about 2.5 neg camber on the rear to tuck them in at the top.
Thanks guys
I want aggressive fitment but I'm currently at stock height but I think I'm a bit lower cos the car is fitted with impul shocks and the springs seem stiffer than others
I'll measure the height later
they will be ~+20 offset
i swapped my rear cradle to an s14 one, so fitment is the same as an rs4-s
ran
18x9.5+2 235/40 silverstones -2 deg camber front
18x9.5+1 235/40 federals -0.5 deg camber rear
close mate, according to my measurements (can't read japanese) it looks like they are +12. they were tucked in alot better when it was running 3.5' neg on the rear, but i was also destroying tyres even after setting up the toe accordingly.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
