Thought i'd see if you guys know abit more than over from the gtr.co.uk forum,seems to be more infomation on starter motors and stuff here than there...
my GTR was parked up for about 3 weeks,went to start and just got a single click. the starter motor has been fully re-conditioned,and battery has been fully charged and all i still get are a few clicks
tried a different battery and still got the same problem,also tried jump starting but nothing
now,which wire is the postive and which is the negative on the starter motor? i'm guessing the small "spade" is the positive and the 12mm is the negative? i need to try bridge it apparently,but i'm not sure on how to try this out..
also,i'm going to try jump starting it again,but instead of using the negative in the engine bay,i'll be putting the negative somewhere else in the engine bay,where would you say is the best place to put it?
need the car fixed asap aswell,ran out of ideas now!
also relays,where/what do i need to check? all the fuses are fine,checked them all and also wobbled them around
thanks
https://www.sau.com.au/forums/topic/339252-r33-gtr-not-startingjust-clicking/
The "spade" is the trigger from the key (when you turn the key to START). The large cable - coming from the battery - is +ve power to the windings of the starter motor. The solenoid, activate by the "spade", connects +ve power from the big cable through the starter motor, and earths out thorugh the starter motor body to the engine block.
When jumping, try connecting the -ve connection to the engine block of the car being jumped ie your GT-R.
You can set up a relay that uses the "spade" as the switch to supply direct battery power to the starter solenoid.
excellent post thank you!!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
