Hi there, I've bought an R33 GTR with a single turbo conversion. Its a monster, and its pushing 275rwkw at 15psi; when tuning it they increased the pressure to 17psi and it pushed well over 300rwkw, but they wound it back to 15psi because they said the stock head gasket wouldn't handle it and I need to replace it, the pistons, and conrods before looking at the injectors and fuel rail. I was under the impression the stock internals would be good for up to 600hp; are the forged or not? how much psi can the head reasonably take? I'm sure there is a thread on here somewhere about this but I can't find it, so would be very appreciative if someone could give me some answers.
Well the internals aren't forged so 600hp might be a bit much.
But I don't see why you could upgrade injectors computer and fuel pump and go for 300-330 rwkw?
Just note I'm no expert so don't rely on what I say :P
Edited by gtr fan
Thanks for that; I'd be happy with 450hp. It already made over 300rwkw with stock injectors and pump, and has power fc commander, my mechanic is telling me the head and internals are the limiting factor and I'm starting to wonder if they are trying to generate some business for themselves. It would be great if I could just add a few more pounds without spending big $$.
Leave it as is until you have the money to go for a rebuild ($10k +).
If you want to run big power, realiably you will need some big cash to go with it. The wagon in my avatar had 500rwhp, its still going today. It cost around $15k to put together.
Thanks, I guess I'll just enjoy it as it is. It's a shame though, as the turbo the last guy put in it (only just run in- I removed the rev limiter) was chosen for a 500hp setup. It's not very efficient running such a large turbo at low boost right? Is there any other reason that may justify me doing a rebuild?
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
