  • Replies 89
Some idiot smashed it when it was parked near Tas Brakes... OR some kids...
I want to hit them very hard...
But it happens... Hey man I am getting the engine sent up tomorrow and put in the Car next Tuesday...
I have from Monday to Thursday Free this week to get that car moved...
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-688025
cool id say tuesday night if i can get donkey out with the car,
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-688251
oh an dnice to finally meet you scott, along with ur mate (don't recal his name) in the 200sx
Yeah it was good to meet you guys!. Put some faces with the cars lol.
Guy with the 200 is Rodney or Brownie as he likes to be called.
When i left the carpark the other night i gave it a little and guess who was in the middle of the street but a policeman waving his arms. He threatend to send me to the RTA for a veichle inspection(shittin myself bout now). "Didnt you know that its illegal to have a blow off valve venting to the atmosphere?" he said. He gave me a undue noise fine instead(thanks officer!). :Bang:
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-688708
I wonder how long it will take for me to get done once I have finished putting my new turbo on, ive got the wastegate venting to the atmosphere hehe :flamed:
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-689142
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-689143
just tell them to piss off! And if they book you for undue nosie ask them about the all the Harley Davidson bikes with no mufflers driving round! Don't see them pick on bikies!
Or just tell the officer the car cam from japan and the BOV is standard...... easy. They don't know everything!
its worth a try!
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-689422
You mean to say a cop here actually knew what one was?
Got a ticket once in my old lancer coupe for speeding, on the ticket it said magna sedan... dipshit.
oh, and good to meet you guys too.
I got done for speeding and the cop put the wrong date on the ticket wrote 2001 instead of 2002 still haven't payed the ticket cause invalid!
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-689423
what sort of boost gauge is it (white face) light up blue ?
Boost gauge link
http://www.skylinesaustralia.com/forums/sh...ead.php?t=34485
decal and Badge link
http://www.skylinesaustralia.com/forums/sh...ead.php?t=34486
https://www.sau.com.au/forums/topic/33928-pics/page/2/#findComment-690753
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
