G'day everyone,
Well my name is Scott, I live in Shellharbour.
I imported an EVO5 for the misses 6 months back (she likes the look of the 5)
I am the owner of a R33 GTR Tommy Kaira that has been sitting in japan for the last 2 months waiting on import approval, now after all this time trying to get to the bottom of it all I have tracked down the buyer & he has sent me the pictures of the car. I find the car has had its chassis number removed fromt he firewall & the only serial number is a serial number 868 stamped on the left strut tower.
I am hoping that someone can advise me if this is normal for a Tommy Kaira car to have it's chassis number removed?
The buyer in japan is now trying to resell the car on behalf of me (because it will be easier than trying to import it)
But he has told me I am going to be out of pocket. Oh & the so called broker I was dealing with in sydney has vanished.
Thanks for any advise
Scott
https://www.sau.com.au/forums/topic/339365-sick-of-waiting/
Hey mate
Whilst I'm no expert of this. Any removal of numbers sounds dodgy to me. Plus the disappearance of a broker sounds equally as sus. I would keep as closer eye on this as possible to make sure you get as much $$$ back as you can.
Cheers.
Luke
https://www.sau.com.au/forums/topic/339365-sick-of-waiting/#findComment-5484703
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
