Hi guys,
Im tossing up spending $380ish on a sard 280L/hr pump and have it fit straight in or spending $200 for a bosch 044 and custom fitting that. Now ive looked over all of the articles etc on fitting and modifying the gtr cradle to fit the pump but has anyone in perth actually done this and can anyone reccomend places where you can actually get the fittings needed i.e. the 90 degree elbow for out of one end and the spear fitting at the sock/filter end?
Cheers guys,
Kagan
https://www.sau.com.au/forums/topic/339367-bosch-044-into-a-33-gtr/
Hyperdrive charged me ~$220 to fit my 044 internally and that included them supplying all the fittings/filter required and rewiring it. It's what they run on their drift cars and my mate has the same setup supporting well over 500rwhp.
Edited by bubba
Personally I'd go for the direct bolt in. If you need extra flow in the future then get a surge tank and an external mounted fuel pump
What sort of cost would you be looking at for a surge tank setup??
Depends how much you can do yourself :P
You can buy a 3ltr surge tank for about $200, then you need an external pump, and some fuel lines and fittings. We went solid lines on mine, and there is no smell at all :rant:
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
