Hey guys so we just received the first HKS GT800 turbo kit this is fresh off the production line just thought i would share some pics with you guys. The best feature i believe is the Symmetrical design of the turbo chargers something non of there competitors have done. this kit is a work of art i think the picture speak for themselves. Also in the photos is the new HKS Dual Clutch Transmission sump extension/stiffener.
Uploaded with ImageShack.us
For any further info don't hesitate to contact us
HKS PRO DEALERS
Email: [email protected]
Phone: (07) 33569401
https://www.sau.com.au/forums/topic/339383-hks-gt800-kit-in-stock-photos/
Hks Japan has spent a hell of alot of the last 2 year concentrating solely on response and reliability. This can be seen on the graph below which is unbelievably impressive the GT800 turbo kit is more responsive than the factory car and there is only an 800rpm range in which the boosted up GT600 kit has it down low.
This combo will be near unbeatable on a track.
dave
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
