Hi All,
I am wondering what is the most power someone has made through a standard RB25 intake pipe? (it can be sleeved with pipe)
Mine is currently making 279rwkw and i am wondering if it has much left in it. I am running an apexi pod filter, it can be either airbox or pod as long as its running through the standard intake pipe.
Any help much appreciated.
Thanks guys, i am running a hiflow with the standard comp cover so standard 2.5" intake, so I cant see the value in anything bigger than the factory intake pipe. Tao from Hypergear made 302rwkw using the same turbo but with a 3" metal intake pipe so I am just curious to hear some other real world results. I am hoping for 290rwkw.
Run 3inch intake pipe. Will make better power, response, and keep the turbo cooler. You will find metal sleeve does all sort of strange things. 60rwkws difference on mine, It did not work for me.
Run 3inch intake pipe. Will make better power, response, and keep the turbo cooler. You will find metal sleeve does all sort of strange things. 60rwkws difference on mine, I did not work for me.
Thanks Tao, I know your advice and I do value it.
I dont see the difference between:
pod > 3" afm > 3" pipe to 2.5" turbo inlet
pod > 3" afm > 3" pipe to 2.5" pipe to 2.5" turbo inlet
The only difference is that the standard pipe reduces to 2.5" (same size as turbo inlet) 8 cm earlier.
I understand completely if the turbo inlet is bigger than 2.5" but I just cant see the logic yet. If I lost less than 10rwkw I would accept that as my engine bay looks completely factory with a pod (my intercooler is also very hard to spot).
Oh well we will find out next thursday if it will max out.
I was recommended by unigroup to upgrade the intake...
i did make good power so i suppose it must have helped.
Thanks for your experience, only difference is you are running a turbo with a 3" inlet so using the standard intake would be an obvious reduction in diameter (2.5"). Also it just wouldnt fit.
I just made an 80mm alloy intake for GTR 26 on his 34gtt, it will be interesting to see the gains on his 3076 once Trent tunes it, I think the stock rubber intake maxed around the 270 mark.
Bigger is better for the suction pipe, and a good bell mouth into the turbo helps.
Interested in this myself.
I'm currently running 250rwkw on the standard pipe and have always wondered if it's upto the job. It's been reinforced with some pvc piping but there's a pretty nasty bend in it and the bend isn't reinforced.
Having less length of the 2.5" piping will increase flow and i'm sure the aftermarket piping will have a smoother internal make up and most important a smooth bend whilst not collapsing at all under vacuum.
I wonder if changing the pipe will bring enough difference to require a retune as that's whats holding me back from changing the pipe (and a couple other higher priority items i want to replace).
I made about 30 kw more with mine so yes, you should definitely get on the dyno at least to check afr's top end.
Cheers mate - What engine/setup was that on i.e. Your vq or on an rb motor?
Yeah thought the tune would need to be tweaked... i might leave it then as i'm pretty happy with the power anyways. When i do change it eventually i'll do it at the same time with a forward facing plenum and a retune to suit.
WOMG DOSE!
Edited by Touge Kyousou
WOMG DOSE!
Mine is VQ25det, but flow into a turbo doesnt change with engine type. Suction pipe size is important as the air isnt compressed like Stao mentioned, its at less than atmospheric pressure so less air travels down a 3 inch intake pipe than the turbo can blow down a 2 inch, good power gains to be made there.
3" alloy hard pipe, split the stock rubber intake down the middle, then wrap it over the alloy pipe. As long as you cut it correctly and use an extra hose clamp it will look factory.
I'd also run a stock air box with some 'slight' modifications to cut down on the fuuuully sizacccc 'dose' sound.
J.
Edited by XRATED
Cheers for the info. Good idea on wrapping the factory pipe over an alloy one too, hrmm!
I was looking at getting a silicone intake pipe in black though so should still look fairly harmless, and being silicone shouldn't make noises anymore hektik..
Ahh on a vq. I agree on no difference with air going down the turbo however the factory design of the intake pipe between an br25 and a vq25 would be vastly different i'd daresay e.g. one is happy to flow decent whereas the other may not. E.g. on my v35, that intake pipe had a large and a smallish resonator tee'd off for NVH whereas a skyline from the 90's probably wasn't as focused on NVH. Damnit, now i'm looking at intake pipe, plenum, and retune blargh! (i'll do it later)
That will be very interesting, if you could update this thread with the results that would be great! :(
Yeah if those bellmouth things make more hp I can see the benefit of having a larger intake pipe immediately from the turbo.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
