pretty sure that the first bend of the piping is the original hard piping yes. BOV return has been welded up though!
Ah nice one! That was where i thought nah too hard basket. Pics or ban :D
Should have listened to you Manuel and Tao!
Had my car on the dyno yesterday and with the sleeved factory intake pipe it would not make more than 250rwkw as the part close to the turbo where it is still 2.5" is sucking shut. Bugger!!
Off to get a custom intake made up and back on the dyno.
i thought you said you made 279rwkw (in your first post)?
That was with a temporary custom 3" intake pipe. The problem is that it did not have spots for the bov return and the breather which I want. So then I tried putting the factory intake back on with the pipe inside. That is when it would not make more than 250rwkw and I know which just the 3" intake changed it made 279rwkw.
First setup:
Custom 3" intake, bov blocked off and breather hose to atmosphere.
279rwkw
Second setup:
Factory intake with pipe, all factory fittings so bov and breather connected to intake as per factory
250rwkw with intake sucking shut.
Next setup:
3" metal intake with bov and breather fittings.
What filter are you using?
Apexi Power Intake
https://www.justjap.com/store/product.php?p...cat=&page=1
Trent said he had seen some big power setups with this pod so didnt think it was a problem.
Ok I suppose its less prone to sucking shut near the turbo, would be smoother and seems to have more space around the fittings so that they dont disrupt flow.
Do these metal rings do anything?? This pipe is exposed to suction not boost. I would have thought metal rings on the outside of the hose would only help under boost, ie to stop it bulging out as much? The JJR one looks to just be a rebranded Autobahn 88 one. I bought one of the Autobahn ones a while back and wasn't impressed by the fit (or lack thereof) at all. No matter how I tried to trim it the thing just didn't sit right.
I have issues with power dropping off and then coming back above 5000rpm which sounds similar to the issue mentioned previously. I have a 3" piece of stainless in the large ID section of the standard intake pipe so maybe I'm having issues with the smaller end near the bend closing? I'm running 18-20psi with a GT2530 but only getting 200rwkw so somethings holding it back.. figure isn't on the intake side or the exhaust side.
Anyone else used one of these intake pipes with the metal rings? If so I'd love to hear about any opinions of what they have experienced.
The metal clip goes in between the ribs so if the pipe was to suck shut it would pull the ribs together and have to squash the metal ring, obviously there isn't enough suction to do that so it should work fine.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
