Reading through other's posts through the search function, Im confused between personal import and other types of import schemes and how to comply them.
My car is a s12 silvia Japan version bought in from NZ as a personal import. Have all the documentation to get it complied but have no idea where to start.
Can I keep my mods on this car (full roll cage including side bars, racing seats, 35r turbo, aftermarket management...) or does it need to be returned to standard?
What else is needed to get it complied?
Last of all, where can I take it to for compliance (Gold coast area) and how much does this cost?
My apologies if this duplicates other's questions.
https://www.sau.com.au/forums/topic/339398-personal-import/
what???
you mean you're bringing a S12 silvia over under australia's "personal imports scheme??"
why bother?? personal import is for people who NEED to bring their cars over - it's costly and difficult with australias regulations..
your car is pre 1jan 1989 build, yeah?
bring it over as that.. (bring it over as a pre-89 scheme car) - that means.. all you have to do is.. apply for import approval, pay for freight and customs.
then change things on the car to comply with the Austrlaian design rules of that year - which are basically nothing.. maybe change a fuel filler funnell or something and have the work signed off by an engineer..
then get it registered!
EASY! (well not EASY but not as difficult as a "personal import" scheme car
https://www.sau.com.au/forums/topic/339398-personal-import/#findComment-5482383
Thanks for the response.
Sorry I wasnt clear. I already have the car imported under the personal import scheme (well I bought it off a mate who imported it and who Im still in contact with).
So to clear it up, the car is here in Aus. I have 4 documents:
(1) One that authorises personal import plate
(2) Document of compliance (to be completed by compliar) to be given to transport authority
(3) Owner's document of compliance (same as 2, except kept by owner)
(4) Customs clearance document (states import approval is granted)
Compliance needs to be done before personal import plate can be granted.
So I guess from what you say I can keep my mods and take it to an engineer.
Where can one take such a car to on teh gold coast?
https://www.sau.com.au/forums/topic/339398-personal-import/#findComment-5482688
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
