Hey, i had a search and found a few bits of discussion but not really a straight answer.
Looking at the 3076 kit from gcg HERE.
There is an option for a regular 2.75 inch inlet or the surge slotted 4 inch inlet.
Im having trouble working out the differences between the two (aside from people liking the sound of the surge slotted ;)).
I figured the 2.75 inch would be less hassle cause i could stretch the standard intake pipe over it to drive to a shop to get a metal intake pipe made up (or would the standard intake with a metal insert work?), not sure how id get anywhere to do that with a 4, i guess id have to organise an intake pipe beforehand? ive never welded anything :)
Thanks in advance!
Thanks in advance!
First decision is will you be running the afm in the intake? If you are it makes the 4" a bit of an overkill if you are going to reduce it down to 3" for the afm anyway. The main advantage of a surge slotted compressor housing is that it will resist compressor surge.
All you would need temporarily is a 45 degree bend with a 4" -> 3" reducer to drive it down to the shop to get one made up.
Have a serious think about the afm location because if you can move it to the cooler piping you can then run a big 4" intake. I am guessing from your turbo choice your not too worried about stock appearance anyway.
Thanks jeff, im trying to keep it as standard looking as i can manage with a 3076 ;) i guess the 2.75 would probably be the best way to go, seems like a hell of a lot less screwing around, just dont want to make a choice ill regret later down the track.
You could just get a 4" -> 3" reducer straight off the turbo then a 3" metal intake pipe to the afm. Just do it all in black.
Not sure about squeezing the stock intake pipe over the 2.75" inlet. I think the general rule is try to ensure that nothing in your intake is smaller than the turbo inlet if possible. Reducing from 2.75" to 2.5" might be a bit of a restriction.
Here are a few of my lessons:
- First thing do not buy an autobarn88 intake pipe for your R34 GTT as it does not fit with an afm, I had to return mine.
- Make sure your blow off valve does return to the intake. I tried blocking my bov off and also using a 1 way valve but Trent reckons the R34 ecu is too smart and is hard to tune around. Even after it was tuned around I still had some popping with gear changes etc. So ensure this is plumbed back to the intake if you do go the custom intake route. I reverted back to the standard intake but I only have a 2.5" inlet on my turbo (of course as its a stock comp cover).
Are you goals 280rwkw and as stock looking as possible or 300rwkw and a little consideration for stock but not too worried? That will answer your question I think.
From my other thread in this section, it doesnt look like many people have gone past 280rwkw on the factory intake pipe, even if it is sleeved. I hope to do so next week.
Thanks for that good to hear what you've learned.
Well if the 2.5 is too restrictive i guess ill need a custom intake regardless if i go the 2.75 or 4.
I havent heard of anyone mention a power difference between the 2.75 and the 4, have you?
Firstly, if you are going to get the 3076, you should get the surge ported .6 AR front cover.
Secondly, I believe the 2.75" version is a .5 AR front cover. Similar to that found on a 3071.
Now, from all the variations of this turbo we have seen people use, the best option is the surge slotted .6 AR front cover. You will make the numbers with this and you will sound like a semi spooling up behind everyone. The 4" intake is honestly a PITA IMHO also. When I had my HKS 3037 (same turbo) I had it with the HKS only 80mm front cover. It is the same one as used on the garrett yet with the 4" snout cut off and a 80mm (3.15") snout bolted on. I would not even start to dream of bothering to make something to replicate this.
However - the turbo I always wanted to run was a 3071. The 2.75" .5 AR front cover is standard to that particular turbo and should not suffer from surge on the RB25. You are likely to be hard pressed to hit the 300rwkw mark as easily, however you will pick up some punch in the lower RPM.
For reference, see usmair's thread of his GTST with 3071 (.82 IW rear housing):
http://www.skylinesaustralia.com/forums/29...l&hl=usmair
See also:
http://www.gcg.com.au/index.php?page=shop....t&Itemid=53
I'm filling in the gaps by using "the force" but id does make sense .
What Garrett call the GT3076R , the real one anyway , was a turbo developed by Garret for HKS and it was called GT3037 . The GT3037"S" came with a port shrouded version of Garrett's 0.60 A/R T04E family of compressor housing .
Now HKS always used their own non Garrett turbine housings on 3037's and they tend to be more compact that the ones made by Garret later on . Also virtually all HKS GT30 turbine housings use the smaller more compact T25/T28 flange size , the exceptions were the GT Pro S turbine housings in IW form for RB20/RB25 and they had the "T3" flange .
Anyhow what happens when you build a turbo with a healthy sized compressor and a compact responsive sized turbine housing is compressor surge . By fitting the surge slotted/port shrouded compressor housing you can make an "all rounder" turbo meaning it doesn't matter if you use small turbine housings because the comp housing resists the compressor surge . HKS made GT30 turbine housings from I think 1.12 A/R right down to 0.61 A/R which is quite a variation in sizes . Believe it or not people used to use 0.61 housings and GT3037's on CA18's and SR20's to make a 300 Kw turbo spool up reasonably early .
HKS also had a range of compressor trim sizes in GT3037s , 48/52/56 trims but Garrett usually only brings in the 56T ones . The other year I did some research into the 52T ones and now they are available here as well .
HKS did offer non port shrouded comp housings on 3037's but I think they were aimed at 2L four cylinder apps ie SR20's .
I think the only version that didn't have a port shrouded comp housing option was the smallest 48 comp trim version but AFAIK they are out of production now .
Anyway your call , Garrett make T3 flanged GT30 IW turbine housings in 0.63/0.82 and 1.06 A/R sizes . If you were going to use the 0.63 one then I think you'd need the port shrouded comp housing to avoid compressor surge where you could possibly get away with the normal one using the 0.82 turbine housing .
I'd always grab the port shrouded one where possible because I think it has some performance enhancements , also if you hate lag and opt later for a smaller turbine housing you've got the surge issue covered . As others have said you can fit a reducer from 4 to 3 inch right at the turbo and probably not lose anything in an 80mm MAF system .
If you are not chasing every last kw with big turbine housings you can opt for a 52 comp trim GT3076R , it has a slightly better map than the 56T version and is supposed to be a bit more responsive all else being equal .
You call , A .
I run the 4" anti surge inlet.
Alot of people say they sound loud as they spool, but I believe that is to do more with type of filter you have.
I still run the factory airbox and panel filter, so no pod.
The induction noise is no louder than the stock turbo with airbox. When I first got my car it had the stock turbo with a HKS mushroom pod filter and it was very loud. I removed it with 2 days of owning the car.
Attached are couple of pic's of the inlet. 3"-4" reducer on turbo inlet, 3" 90deg alloy bend and 3" 45deg silicone bend onto airflow meter.
Pic's do not show engine breather return and bov return, but hey now welded into the inlet
If you need more pic's or where to get bits that do not come with the GCG kit, PM me
Refer to the HKS website - the 52 trim 3076 is available in 2.75 non-surge or 4 inch surge.....from memory the bigger 4 inch surge was rated at slightly more power - a difference that might be carried across to the 56 trim 3076.
Edit,
Here's the link - you will note the 4 inch cover is rated at 10hp more that the 2.75 inch cover in both the 52 trim and 56 trim.
http://www.hksusa.com/categories/more.asp?id=1092
Edited by juggernaut1
Edit,
ah interesting! thats good to know, thanks for that.
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
