I use them for day to day use. Not a bad tyre for street duty at about 180rwkw. Never put them through their paces on the track though.
That said I will most likely be upgrading next time I am in the market to tyres to something a bit more track orientated.
https://www.sau.com.au/forums/topic/339444-toyo-proxes-4/#findComment-5486545
Had them on my old r32 215/35/18 on fronts, and when they got old I put them on the rear and they were ALOT grippyer than brand new 235/35/18 Nankangs I usually had on rear. Not that Nankangs are much of a tyre, but I was very happy with the proxy 4 all the time, exept one delimitated on front due to 2.5 deg neg camber, and shop told me it's my fault for "shitty" camber so no refund. They lasted 10,000km on front
https://www.sau.com.au/forums/topic/339444-toyo-proxes-4/#findComment-5500973
Had a pair of these on the front of the RX when I had it, with Potenzas on the rear. Saw some pretty hard street driving but no track work. Was very happy in what I paid/what I got. Didn't have any dramas but read alot of reviews saying hard work an time (year or so) caused trouble. Eggs, poor response etc...
https://www.sau.com.au/forums/topic/339444-toyo-proxes-4/#findComment-5500988
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
