  • Replies 54
Taleb tyres. Sau for sale section in business section.
Got quoted 280 a tyres for 265*35*18's delivered
But for what sort of tyre?
If I had an R33 GT-R I would only be putting good tyres on there. Toyos, Yokohamas, Pirelli, Continental, Dunlup etc.
http://www.tirerack.com/tires/TireSearchResults.jsp?customSizeSearch=&width=245%2F&ratio=40&diameter=18
Shipping has never cost me more than $350 to Sydney.
Takes about 1 week to get to your door.
So far I've had Dunlop Direzzas Z1 Star spec and Hankook Venus R-S3 from here, excellent service and it worked out half the price for the Dunlops and $400 cheaper than anywhere in Australia for the Hankooks.
The savings are only worth it if you buy high quality tyres though, but then you are getting top quality tyres for the price of average ones anyway.
Yes I am a tirerack fanboy.
Shop smart, Shop S mart.
Get on there and send him a pm, has everything for a great price, will have a look and let u know what tyre they were
Oh I have, costed me up on a set of Toyo R888s, very reasonably price.
Still nowhere near $280 per tyre delivered for something like a big 265/35R18 :blink:
Tirerack for quality tyres at the price of average tyres locallly, but only worth it if your getting top end stuff, very happy with my tirerack purchase, of Michelin Pilot Sport, excellent grip and wear, $650 each locally or $1400 for a full set delivered thumbsup.gif
I'll be trying Pirelli P-zero next time..
How much was delivery, if you don't mind me asking?
Ive tried KU31's and i had problems with them at high speed and shit wearing characteristics.
+1
I would never put 595's on my car
Have you ever driven on 595s? Considering they are a relatively hard compound they still grip VERY well in the wet compared to other tyres that suit daily driving and supposedly last long also.
If i was to buy tyres for my gtr again i would buy federals again no doubt about it, im pretty fussy about daily tyres and im happy with them in every aspect! As for a track tyre i would definitely buy a softer tyre, possibly toyo t1rs but why drive on a soft high performance tyre on public roads if ur not going to use them to their full potential?
I dont get why people knock a tyre if they havent tried it.
From memory about 300. that was a while ago.
Just ordering some 255/50/19. For wife's kluger and the freight is $335 So basically getting continentals for the price of a much cheaper brand locally. Only time will tell if they are better than the bridgestones that are coming off. Having only done 30k with obviously no track work ?
I've driven on them on my old housemates car.
When RE001's are a mid priced tyre, last 30-40k km, and grip fantastically wet and dry, I don't know why you would put shitty 595's on it when tyre's are the only thing keeping your car to the road, irrelevant as to whether you use them to their potential- emergency braking is never planned! You would think someone who owns a GTR wouldn't be scared to spend an extra couple of hundred for better rubber.
road car BUDGET- Federal 595SS
street car - Pirelli PZero,Bridgestone RE001aggressive street, weekend track: RE11's, KU36's, 595RSR's (all 180ish tread wear, 'semi style' tyres)
track car - Bridgestone RE001 RE55 or similar R comp.
That statement isn't accurate. You have listed all 'street' tyres above 200 tread wear... Fixed it for you cheers.gif
Edited by RB_Ryan
Tyres are the best performance upgrade for your car, people go on about eBay shit being bad then skimp on tyres.
The only thing stopping you from putting your power down or crashing is the tyres.
Hard cheap tyres are for taxis.
Review. http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=EP
Review. http://www.tirerack....lay.jsp?type=EP
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
