so ive been working on my rb build for about a year now and had a few motors in this 240sx. i first got it running back in Jan for bout 3 wks but the transmission broke so sourcing parts and research took awhile so i just bought one. then while the car was down i desided to put another turbo in it. i went from a 50 trim which i made 520 whp to a turbonetics T72 turbo which i have right set to 15psi (dont know the exact hp) i had 880 injectors and replaced with 1000's (im on e85) the other motor had a lil bit of a porting job when i got the motor, head gasket, greddy timing belt, head studs, r34 rb25 n/a short block. now that motor was ok on power(at the time i thought was really good) it was a lil bit sluggish in the off boost parts. well after i had put the new turbo and injectors on that motor i had took it out and not knowing one of my fuel pumps failed and BAM there goes cyc #6. so i got a new motor completely stock in put it in there with the same aftermarket parts with the same tune and this motor rocks hard. so far on my tune im getting that turbo to be at full spool on 15 psi at 4800 rpms an redline to 7k( will raise when i change the belt, its loose). idk the power but it fells ALOT better than the other setup by far i dont much pic of the car but ill show you the work over time and what happened to it after the last motor blew, it caught on fire. i will post new pic of my new setup prob tonight
this is at the car show in Jan old setup
this is when we got it working the first time
this is what happens when cyc #6 has no compression and alot of blow-by
https://www.sau.com.au/forums/topic/339501-car-is-finally-coming-together/
^ lol :(
As for the power/turbo 385rwkw/520rwhp with boost (only 15psi) coming on 4800rpm - did i read that correctly?
If so, that's fairly average mate.
Also did i read that it's running on a stock motor as well?
What trans did you use? 25box?
I'm not sure any rebuilt SR box will take that for very long
I did come across the original build from some US car forums, and she's the actual mechanic who made this happening from scratch. Pretty amazing for a chick.
Bit sexist yeah?
I know chicks who rebuild 800hp twin supercharged diesels in tanks way better than what I could.
I loved watching the Dutch birds, nothing better than a blonde big boobied girl hanging out the top of a tank whilst she drives it around trying to look menacing, even war stops to watch..........
Looks good, should get it up on the dyno and post up a dyno sheet.
2nd girl in those pics is....yuck lol.
and i like the wheels, what sort are they?
sorry bout the delay, i was very sick. the wheels are called venaci they come out of the same factory as rays and are from japan
^ lol :D
well on 15psi is prob around 500whp but the motor is stock and the tranny is an rb25 aswell
nice looking S14, and I don' say that often :D
thanks im working on making it better looking.
i just turned up the boost to 18 psi and boy was that alot to handle. i love this car. it feels like it still has room to go but i like her to have alot of life in her.
I think I have an .96 ar housing or 1.09 ar housing on a t72. The Q is, what size should I go down to to make it spool up round 4000 rpm. It spools now at 4900. I was thinking somewhere around a .81 r .84 but didn't know know if that will be to small
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
