so ive been working on my rb build for about a year now and had a few motors in this 240sx. i first got it running back in Jan for bout 3 wks but the transmission broke so sourcing parts and research took awhile so i just bought one. then while the car was down i desided to put another turbo in it. i went from a 50 trim which i made 520 whp to a turbonetics T72 turbo which i have right set to 15psi (dont know the exact hp) i had 880 injectors and replaced with 1000's (im on e85) the other motor had a lil bit of a porting job when i got the motor, head gasket, greddy timing belt, head studs, r34 rb25 n/a short block. now that motor was ok on power(at the time i thought was really good) it was a lil bit sluggish in the off boost parts. well after i had put the new turbo and injectors on that motor i had took it out and not knowing one of my fuel pumps failed and BAM there goes cyc #6. so i got a new motor completely stock in put it in there with the same aftermarket parts with the same tune and this motor rocks hard. so far on my tune im getting that turbo to be at full spool on 15 psi at 4800 rpms an redline to 7k( will raise when i change the belt, its loose). idk the power but it fells ALOT better than the other setup by far i dont much pic of the car but ill show you the work over time and what happened to it after the last motor blew, it caught on fire. i will post new pic of my new setup prob tonight
this is at the car show in Jan old setup
this is when we got it working the first time
this is what happens when cyc #6 has no compression and alot of blow-by
https://www.sau.com.au/forums/topic/339501-car-is-finally-coming-together/
^ lol :(
As for the power/turbo 385rwkw/520rwhp with boost (only 15psi) coming on 4800rpm - did i read that correctly?
If so, that's fairly average mate.
Also did i read that it's running on a stock motor as well?
What trans did you use? 25box?
I'm not sure any rebuilt SR box will take that for very long
I did come across the original build from some US car forums, and she's the actual mechanic who made this happening from scratch. Pretty amazing for a chick.
Bit sexist yeah?
I know chicks who rebuild 800hp twin supercharged diesels in tanks way better than what I could.
I loved watching the Dutch birds, nothing better than a blonde big boobied girl hanging out the top of a tank whilst she drives it around trying to look menacing, even war stops to watch..........
Looks good, should get it up on the dyno and post up a dyno sheet.
2nd girl in those pics is....yuck lol.
and i like the wheels, what sort are they?
sorry bout the delay, i was very sick. the wheels are called venaci they come out of the same factory as rays and are from japan
^ lol :D
well on 15psi is prob around 500whp but the motor is stock and the tranny is an rb25 aswell
nice looking S14, and I don' say that often :D
thanks im working on making it better looking.
i just turned up the boost to 18 psi and boy was that alot to handle. i love this car. it feels like it still has room to go but i like her to have alot of life in her.
I think I have an .96 ar housing or 1.09 ar housing on a t72. The Q is, what size should I go down to to make it spool up round 4000 rpm. It spools now at 4900. I was thinking somewhere around a .81 r .84 but didn't know know if that will be to small
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
