I see what you are doing. once suggestion I would make with that auto though is a SERIOUS trans cooler for it. if that box is anything like a subaru box (both are jatco) then a rebuild on it is over $4k.
Currently, the engine guy doesn't think the auto will last behind it. The transmission is going to Paul from KEAS, who seems to really know his stuff. Yes I agree with the trans cooler.
  • 2 months later...
The bill for the Hypertune one off plenum, fuel rail, (plannning ID2000 injectors), and 90mm throttle body, was solid, got to pay the bill for the street head port as well at the end of last months other bills....solid accounts. This months is bite the bullet with the oil pump. I'm initially trying Nismo, non N1 pump with hardened steel gears (not an N1). Using the N1 water pump. Gaskets are a mix of factory Nissan, but using the Tomei RB25 det head gasket.
Edited by WHITE gtt
  • 4 weeks later...
The engine assembly continues. Hypertune plenum and 6 Boost manifold are pleasing products to look at. Hypertune plenum needs fettling for VVT.Got some compliments on the 6 boost twin scroll manifold, with twin scroll turbo combo.
Edited by WHITE gtt
this is a pretty sweet project man. :thumbsup:
What are the plans for it? daily, weekender or track warrior?
At the moment weekender. The build has taken long enough to forget why. I have a Magna and an Audi for daily duties. I had wanted to drag it, but feel less inclined.
more info on the Hypertune plenum pls :)
I guess I wanted one, they look bespoke. They are individual order for rb25det over rb26. I copped a serve from the manifold guy that it will spool later than a Plazmaman plenum. I haven't seen a comparo, There's a thread on Greddy vs Plasmaman. I just wanted one but the other factor was getting the throttle body, and fuel rail as one package. However it's coming off for adjustments so the VVT will work, something that concretely affects spool. The HKS Step 1 cams were chosen to retain VVT.
The transmission choice has been difficult. I wish there was something 3 speed and simple in all wheel drive like C4 ford. Instead the powerglide is available in awd, seen a one off TH400 on Calais turbo. As well Like most people I want some communication at decision time. The plan at the moment is re403a from the 300zx turbo, which has larger components than the re401a in the car, and mating that to the awd housing. The job's going to MV automatics, thanks to communication about the job etc. Other trans builders are yet to get back to me......
  • 2 months later...
  • 11 months later...
The panel beater is always big and critical part of a build. I've been satisfied with the one I've chosen. The pics show how far I've had the car stripped back, which is far enough to respray the engine bay to the matching final colour. And that it's a glass out windows out job.
The other aspect is the decision to "wide body" in many ways subtle is better and I'm and admirer of Chris Rogers restoration GTS4 for that reason. I have wanted to wide body my GTS4 for wide rubber clearance. I went with fibreglass rear quarters and GTR fenders, over going all GTR and stiching in GTR quarters. The plesant surprise is that for an old GTS4 there is very little significant corrosion as many of these were used in mud and snow parts of Japan, while mine has been looking soild structurally.
There are the "dark nights of the soul feelings" that having been stripped back so far, is it just a pile of rubble now or will it come together mostly to plan.
Edited by DR 32R
Having paid MV automatics, the trans 3k stall etc etc, was lost for a while and found again, causing just a small shortening of my life while MV automatics have tracked it down. Hope I see it in the flesh soon.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
