your opinion is shit, one of my best mates is a hwy patrolman and he is the nicest bloke you will ever meet, unless you piss him off.
I have underlined my point. Just because you have a pretty badge and a uniform makes them think they can rule over the rest of us. Why people still defend highway patrol boggles the mind.
Um...they are police officers....its what they do...ie their job is to enforce the law.
Police officers i love. Highway patrol is my problem. They arnt certified for "real police work" because they dont have the qualifications or the capacity to fulfill the roles of a normal police officer.
scummy cops.....if every highway patrol cop lost their job they would all be unemployed because A) they are too dumb to do anything else B) wont make it past the interview for any other job because the employer will see what true ass bags they r.
My 2 cents (plz dont flame) my opinion on highway patrol.
+2
They start out as normal cops you douche
Ye and dont cut it.....
From what i know a police officer must do general duties before they choose their sort of "major", when this promotion time comes they are given offers to serve as a detective etc.... But depending on their past performance of a junior their options are limited. Highway patrol is next to police accounting from what ive been told =P
You're f**king kidding me.
I thought you'd realised that being an idiot on a public forum isn't a great idea to do. Obviously not.
Highway Patrol are trained to be dickheads to people like you, and this is from an undercover officer's mouth (not mine). I was pulled over by one a while ago and had a bit of a chat (friendly too, because I was polite even though I was in the wrong) and was saying how HP have a bad rep in the car scene, and was told they're told to be like that, to catch out people who fire back. That is all. Next time you get pulled over, throw away your hatred for a second, be polite and helpful, and watch their tone change.
Requesting a lock. PLEASE.
bet you $100 that the fine will be given regardless
From what I know, the police officer must follow you for a minimum distance before being able to (gu)estimate your speed and book you. My brother received such a fine a few weeks ago on Victoria Rd and the officer told him that he had followed him for one km.
As has been said countless times before; if you have a legal issue, ask a lawyer for advice.
It seems that everyone has a mate who has "been let off a fine" for x y and z reason.
In many cases it is crap/ irrelevant/ exaggerated/ impossible.
The offer i made to the OP earlier in the thread still stands... and applies to anyone else for that matter!
Edited by Yeedogga
Some of the comments in this thread are an embarassment to SAU. Some of you need to grow up.
Agreed! Sorry PJ, thread locked due to a lack of maturity from a few people posting in this thread.
Grow up, jawgry and DAS KAMU. If THIS were an attitude test, you would have failed dismally!
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
