Hi Guys,
Last month I got a reputable workshop to install pineapples for me. Everything was fine, just tonight while I was taking off the wheels to lower the car i noticed that one of the pineapples is split. I have attached a picture.
I just have a few questions:
1. Is this normal? Is it fine to leave like that? Is it doing any damage to the car if I leave it like that for a while?
2. Is it my bad luck that it is split? Or can i get say Whiteline suspension to replace/refund? Or does it mean it was not installed properly and the workshop may replace it for me?
Appreciate any comments!
https://www.sau.com.au/forums/topic/339591-split-pineapples/
I'm pretty sure they come split from the factory, buutt that looks like it was installed possibly wrong. It looks as tho it has maybe squashed out a tiny bit, is it overhanging much over the edge of the subframe?
Yeah not sure if there split from factory. I compared it to the one installed on the right hand side of the car and there was no split and seemed a bit 'tighter'. Unless the split is facing the front of the car so I can't see it?
In any case i've email the place where it was installed so i'll see what they say.
Cheers!
For anyone that needs to know I got my answer so FYI i have been told:
"Pineapple bushes are meant to have a split in them for the uppers, and you will be correct the other one will be facing away from you"
Thanks Anyways :ermm:
