sounds like it was a fun day out there. well the rain made it exciting for a few people also don't forget that with the rain the track temps would have been lower. so michael those temps would be getting up there on a warmish day. i personally run the A1RM's on my car and for me they didn't need to be cooled down after 3 hot laps mate. i was doing 10 hot lap sessions and there was no brake fade or it felt like it needed to be cooled down.
i remember my first time out there and the whole day i managed a best lap of 1:28:xxx and that was on street tires etc.
You weren't pushing hard enough ;)
  • Replies 94
I'm not trying to bag the A1RM's completely, they held up quite well to the task. and they're right on the money being a transition pad between street and track.
Yeah Madaz you're right the car is heavier than a GTS-t and has 350kw.
Even the instructor noticed small brake fade after 2 laps but he was pushing much harder than me.
The only place i found the brakes to fade was after the hairpin coming around the sweeper and braking into the esses, two big stops in a row was a little hard on the brakes.
Cant wait for the next track day, clutch is being installed later on this week! its slipping bad on takeoff.
I didn't say that you were bagging the A1RM's mate. It was more of a wow factor that you felt brake fade and i with others didn't? do you have braided brake lines?? if not then seriously look into it and some DOT 5 fluid. That will help a lot with the brakes
Yeah i had braided lines made up, the HEL ones didnt fit properly apparently so the bloke who removed my ABS sourced some ADR approved ones.
I'm running Martini GS 610 brake fluid in the car, so it should most definitely be up to the task.
Hey Michael do you have your rotors slotted?
Nah the rotors are std ones, they were low on material too, some were .5mm and others were .2mm off minimum thickness.
I'm also still running the stone guards, will be cutting them off when i put on some RDA slotted rotors. will be going for the RDA ones because they're probably best value for money. haven't heard stories of them cracking.
Has anyone run Hawk HT-10 pads before?
i'm looking into buying some for track days from the US, they're too expensive here, i can save an easy $100 each end on buying from the US
I think you will find that if you have slotted rotors you will get to run longer before you have fading issues. The slots will help remove any glazing that the high temps will cause as well as not allowing the outer surface to get as hot as the outer most material will be constantly removed. Also the slots release the gas pressure that builds up between the pad and the rotor on heavy braking.
lol thats a pretty big call to make helslo :(
i was doing those times consistently ;)
consistantly slow by the sounds of it. michael on here did consistant 1:28s on his first day with front mount, exhaust and coils in his 34 GTT
Did you Have to be a sausa member to do this special track day? As I enquired about this on the first page, asked to be added to the list of ppl keen but got no response? Woulda loved to do this.. But didn't hear from anyone
i think it was open to anyone on the forums here in SA
Oh ok yeh though so but I asked to be added to the list then heard nothing back.. Oh well next time maybe
Sorry bud, honestly missed your post. Had you said something earlier, could have fixed that :)
Apologies
Saved myself $450 odd dollars tho lol.. Woulda been a great experience.
Yeh well I woulda said something earlier but I've had a bit on my mind nd that slipped haha
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
