heslo Posted November 26, 2010 Share Posted November 26, 2010 sounds like it was a fun day out there. well the rain made it exciting for a few people also don't forget that with the rain the track temps would have been lower. so michael those temps would be getting up there on a warmish day. i personally run the A1RM's on my car and for me they didn't need to be cooled down after 3 hot laps mate. i was doing 10 hot lap sessions and there was no brake fade or it felt like it needed to be cooled down.i remember my first time out there and the whole day i managed a best lap of 1:28:xxx and that was on street tires etc. You weren't pushing hard enough Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5568010 Share on other sites More sharing options...
Krishy Posted November 26, 2010 Share Posted November 26, 2010 lol thats a pretty big call to make helslo i was doing those times consistently Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5568019 Share on other sites More sharing options...
Madaz Posted November 27, 2010 Share Posted November 27, 2010 from memory Brezza has 330kw and a heavier car Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5569041 Share on other sites More sharing options...
D_Stirls Posted November 27, 2010 Share Posted November 27, 2010 i was doing 1:23's with A1RM'a and never encountered any fade, that's after 9 constant laps in the 1:23 range. Also my biasing is completely wrong so I've basically only got front brakes Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5569050 Share on other sites More sharing options...
Brezza Posted November 28, 2010 Share Posted November 28, 2010 I'm not trying to bag the A1RM's completely, they held up quite well to the task. and they're right on the money being a transition pad between street and track. Yeah Madaz you're right the car is heavier than a GTS-t and has 350kw. Even the instructor noticed small brake fade after 2 laps but he was pushing much harder than me. The only place i found the brakes to fade was after the hairpin coming around the sweeper and braking into the esses, two big stops in a row was a little hard on the brakes. Cant wait for the next track day, clutch is being installed later on this week! its slipping bad on takeoff. Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5570401 Share on other sites More sharing options...
Krishy Posted December 1, 2010 Share Posted December 1, 2010 I'm not trying to bag the A1RM's completely, they held up quite well to the task. and they're right on the money being a transition pad between street and track.Yeah Madaz you're right the car is heavier than a GTS-t and has 350kw. Even the instructor noticed small brake fade after 2 laps but he was pushing much harder than me. The only place i found the brakes to fade was after the hairpin coming around the sweeper and braking into the esses, two big stops in a row was a little hard on the brakes. Cant wait for the next track day, clutch is being installed later on this week! its slipping bad on takeoff. I didn't say that you were bagging the A1RM's mate. It was more of a wow factor that you felt brake fade and i with others didn't? do you have braided brake lines?? if not then seriously look into it and some DOT 5 fluid. That will help a lot with the brakes Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5574091 Share on other sites More sharing options...
D_Stirls Posted December 1, 2010 Share Posted December 1, 2010 Hey Michael do you have your rotors slotted? Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5574739 Share on other sites More sharing options...
Brezza Posted December 2, 2010 Share Posted December 2, 2010 I didn't say that you were bagging the A1RM's mate. It was more of a wow factor that you felt brake fade and i with others didn't? do you have braided brake lines?? if not then seriously look into it and some DOT 5 fluid. That will help a lot with the brakes Yeah i had braided lines made up, the HEL ones didnt fit properly apparently so the bloke who removed my ABS sourced some ADR approved ones. I'm running Martini GS 610 brake fluid in the car, so it should most definitely be up to the task. Hey Michael do you have your rotors slotted? Nah the rotors are std ones, they were low on material too, some were .5mm and others were .2mm off minimum thickness. I'm also still running the stone guards, will be cutting them off when i put on some RDA slotted rotors. will be going for the RDA ones because they're probably best value for money. haven't heard stories of them cracking. Has anyone run Hawk HT-10 pads before? i'm looking into buying some for track days from the US, they're too expensive here, i can save an easy $100 each end on buying from the US Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5576067 Share on other sites More sharing options...
D_Stirls Posted December 2, 2010 Share Posted December 2, 2010 I think you will find that if you have slotted rotors you will get to run longer before you have fading issues. The slots will help remove any glazing that the high temps will cause as well as not allowing the outer surface to get as hot as the outer most material will be constantly removed. Also the slots release the gas pressure that builds up between the pad and the rotor on heavy braking. Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5576458 Share on other sites More sharing options...
Jap_star Posted December 2, 2010 Share Posted December 2, 2010 lol thats a pretty big call to make helslo i was doing those times consistently consistantly slow by the sounds of it. michael on here did consistant 1:28s on his first day with front mount, exhaust and coils in his 34 GTT Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5576677 Share on other sites More sharing options...
heslo Posted December 2, 2010 Share Posted December 2, 2010 The gauntlet has been thrown down Krishy Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5576720 Share on other sites More sharing options...
scandyflick Posted December 2, 2010 Share Posted December 2, 2010 (edited) im sure krish'lll match the starlet with his shiny new 6 pot brakes. Edited December 2, 2010 by scandyflick Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5576849 Share on other sites More sharing options...
Krishy Posted December 2, 2010 Share Posted December 2, 2010 yeah got a few things lined up before the next track day. Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5576980 Share on other sites More sharing options...
R32.GTR Posted December 5, 2010 Share Posted December 5, 2010 Did you Have to be a sausa member to do this special track day? As I enquired about this on the first page, asked to be added to the list of ppl keen but got no response? Woulda loved to do this.. But didn't hear from anyone Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5579924 Share on other sites More sharing options...
Krishy Posted December 6, 2010 Share Posted December 6, 2010 Did you Have to be a sausa member to do this special track day? As I enquired about this on the first page, asked to be added to the list of ppl keen but got no response? Woulda loved to do this.. But didn't hear from anyone i think it was open to anyone on the forums here in SA Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5580541 Share on other sites More sharing options...
R32.GTR Posted December 6, 2010 Share Posted December 6, 2010 Oh ok yeh though so but I asked to be added to the list then heard nothing back.. Oh well next time maybe Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5580618 Share on other sites More sharing options...
On Edge Posted December 6, 2010 Share Posted December 6, 2010 Oh ok yeh though so but I asked to be added to the list then heard nothing back.. Oh well next time maybe The track days are for members yes Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5580636 Share on other sites More sharing options...
heslo Posted December 6, 2010 Share Posted December 6, 2010 Oh ok yeh though so but I asked to be added to the list then heard nothing back.. Oh well next time maybe Sorry bud, honestly missed your post. Had you said something earlier, could have fixed that Apologies Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5580743 Share on other sites More sharing options...
R32.GTR Posted December 6, 2010 Share Posted December 6, 2010 Saved myself $450 odd dollars tho lol.. Woulda been a great experience. Yeh well I woulda said something earlier but I've had a bit on my mind nd that slipped haha Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5580810 Share on other sites More sharing options...
Krishy Posted December 7, 2010 Share Posted December 7, 2010 The track days are for members yes i think he was asking about the HP track day Cosi. Not the SAU:SA track day Link to comment https://www.sau.com.au/forums/topic/339593-high-performance-driving-course-mallala/page/4/#findComment-5582025 Share on other sites More sharing options...
