You can and it's quite painful and can be time consuming. Have another car handy to allow you to drive to the tool shop to get the right tool you don't happen to have. I found a 13mm crescent wrench very handy, and long extension is needed for the dump to front pipe bolts. You need to get under the car as well as in through the top, take the bonnet off it makes it a bit easier.
1 turbo always has to come off (cant remember if its the front or the back one, most likely the back) to do the dumps. But bear in mind other people have proved the R32 stock dumps can support 350kw.
Can be done without removing turbos, removing front intake of rear turbo is possibly required so the front dump can actually come out. Yes stock dumps flow power no probs but i found a better boost response even from stock turbos with better flowing dumps and front pipe and was worth the effort to have extra push between 3000 and 4000rpm.
from what i can remember front turbo has to removed as dump pipes hit back turbo housing before getting to end of bolts, this is worth every bit of the effort it takes to change, when i did mine with the CES split dumps and equal length y piece i gained 800rpm boost response and just under 40 rwhp and .4 of a second down 1/4 mile and better fuel economy
thanks, for the info
  • 1 month later...
Thanks for this post. I'm pulling my turbos off at the moment, and doo doo's input has helped me, I was figuring out the least painful way of removing the dumps. Looks like i'll disconnect them from the front pipe and pull the turbos and dumps off as one, then dismantle them.
I should put my car on ramps before i started, now I gotta figure out how to get under the bloody car
With what turbos broseph ?
proberbly only worth changing the dumps when you change the turbos, stock turbz are only good for so much power, not to mention are a ticking time-bomb
if ur happy with the power the stock turbos are providing, why change the dumps? if you want more power and your gonna remove and replace the turbos THEN you can change the dumps, saves so much time and hassle...
yeah good idea is drive up ramps then put trolly jack under rear sub frame and you can get good room under car, but if you have already started and not done this then ouch it's goin to be a tuff job
whats wrong with stock turbos i seem to be goin ok with then and if you have some mechanical symophy they last even with 19psi every now and then
dumps help even stock turbos proform better and are well worth the hassel of changing on a 32 gtr
I have done this swap before without removing the turbos but you need to remove the front inlet snout of the rear turbo and the heat shield off the front turbo. Got some pics here with the head and turbos sitting on my bench. It's a really tight fit between the comp housing and dump but with some maneuvering it's possible. If it's too tight you can undo the nuts (but not completely) for the rear turbo to give it some room to move but it shouldn't need to come off. (putting aftermarket dumps back on is easier). Hope this is helpful.
Edited by doo doo
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
