Hey guys,
Just thought we'd give you a look at what we plan to release later this month.
Our 1000hp R32 GT-R intank kit is in the final testing stages now.
It's completely made here in Australia of CNC billet aluminium.
Includes all fittings, relay, fuel pumps, filters, Gates submersible hose
Say goodbye to fuel odour in the cabin, hello to quiet operation and of course no one will even know you have it.
Simply bolt it in and off you go!
It will be priced at $1350
Also in the pipework we have the same kit to suit R33 GT-R, R34 GT-R, R33 GTS-T, S13, S14, S15, 2001 onwards WRX, FD RX-7
www.powertune.com.au
  • Replies 40
It will be exactly the same as factory, so ultimately for a circuit car you would still require a surge tank, but for the majority of big powered street cars, this will do the job and saves a lot of stuffing around.
for 1300 bucks it would want to do everything, I can see $300 worth of fuel pumps, the hose would cost 20 bucks and a bit of machine work.
I feel its over priced, when for 1300 bucks I could have 2 044 pumps (which would actually flow 1000hp worth of fuel), braided lines everywhere and a good surge tank.
Ps. not sayings its shit, its looks mint! but im not sure a single 5/16" fuel line to the rail and 2 walbros will support 1000hp
Its actually quite reasonably priced in my opinion. That part of my fuel system cost alot more than that, seeing how its all custom.
This is a straight bolt on solution with all the guess work taken out.
X2. Its neither an arse nor an elbow. Not suited to track work and way too pricey for what it is for a street car.
What he said, Im looking to upgrade fueling, but couldnt you add a surge tank in the mix, not many 1000hp street cars but lots of lower power cars that see the track/drags.
I may buy something like this if it could eliminate surge and supply ample fuel and still be all hidden away in a tank.
What he said. Looks like a nice, well engineered kit. But what market, BIGhp that doesnt get raced on low fuel as not o carry needless weight?!?!?! Sure you will still sell plenty as a well engineered fuel system saves a lot of labour costs
Edited by Roy
i am a week or so from doing a surge system , and in my opinion ( that's right mine) its too costly for what it is , i rekon with a few hours i could knock that up and add 2 bosch 040's and away u go.
and just for example .
surge tank with mounting brackets for 2 bosch 044's : $180 au devilered (at this price hardly worth making my own)
2 bosch 044's 200 bucks each
few ods and ends
+ this actually stops surge issues , i cant see how that system will
so well under 800 bucks u have a fuel system thats rated to well over 1000+ hp
not taking credit away it is a good idea, but i just don't think it would a big seller
Edited by yogibear
c'mon Roy, 90% of big hp cars don't see the race track at all, 9% see it on the internet only. I guess 1% may visit a track once. 3 big hp GTRs in Aus regularly do track work.
so there is a market for this.
And you can be sure that billet fitting for the tank lid that seals properly costs a mint to produce. Looks excellent and much safer than the dodgy fittings most people use
On the positive side it looks well made..but does not address the fuel surge issues as already said & it is overpriced for what it is.
If the price was considerably lower it probably would be a fast selling item ..im sure people would overlook the surge side of things not being addressed if it
allowed them to supply the fuel demands needed at a reasonable price.
Exactly, if it were well under 1000 bucks It would sell like hotcakes, Hell I would have been asking about them for R33s if I still had mine.
It looks really good but like everyone else I'd be worried about the surging issues as my 33 is used for drift. May be interested once more details are released as was looking at going bigger pumps etc as i'm looking at changing to E85 and aiming for 400+rwkw.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
